Start/Stop VPN based on Network Traffic of App X
mikeparkie
Post by mikeparkie »
Hi there,
I've been using EG for some time (current version 0.4.1.r1694) but for the life of me I cannot figure something out. As the title says I would like to start my VPN when a certain program is running, when the network traffic stops i.e. download complete, I would like it to stop the VPN. I have the VPN tasks in place and they were perfectly, I just need help with the networking monitoring. Using Windows 10 x64.
Thanks in-advance.
mikeparkie
Re: Start/Stop VPN based on Network Traffic of App X
Anyone?
yeah i can help ya with that, you are going to have to run a CLI command to start the vpn up
but there is way more specific information i need.
what exactly do you need to monitor??
is it a program running or something on the network???
are you trying to run the VPN that is built into windows??? or turn it on in a router??
you would need to have EG run this command
to start the VPN
C:\Windows\System32\rasdial.exe "VPN" "username" "password"
and this command to stop it
C:\Windows\System32\rasdial.exe "VPN" "username" "password" /disconnect
as far as the program running i would say Process Watcher is the way to go it's in the eg plugins
that will post an event when a program runs and closes
so you would create a macro and put the event in it for the program that launches that you want to watch
so here is the xml for the launching of the commandline thing (haven't tested it but it gives you the idea)
<EventGhost Version="1700">
    <Macro Name="Start Program" Expanded="True">
            System.Execute(u'rasdial.exe ', u'"VPN" "username" "password" /disconnect ', 3, False, 4, u'C:\\Windows\\System32\\', False, False, u'', True, True, False)
it will be something similiar to that.
if you copy the code and then right click in your eg tree and select paste it will make the macro
the network thing i am not sure what you are exactly trying to do with that but if the program closes after it is done downloading then you are good because that will generate a event
