Hi there,
I've successfully used EventGhost under Windows 7 and 8.1 for the last couple of years. I upgraded to Windows 10 last week and now EventGhost crashes before it even loads the user interface. I've tried uninstalling and reinstalling which makes no difference.
I *may* have accidentally deactivated a service/feature that EventGhost requires under: "ControlPanel \ Programs \ Turn Windows features on or off". However, I've tried re-enabling most of the services that could be relevant and it doesn't fix the problem.
Here's the log:
21:58:05: 0 MainThread: ----------------------------------------
21:58:05: 0 MainThread: EventGhost started
21:58:05: 0 MainThread: Version: 0.4.1.r1700
21:58:05: 0 MainThread: File "C:\Users\robimart\AppData\Roaming\EventGhost\config.py" does not exist.
21:58:06: 0 MainThread: missing guid in plugin: C:\Program Files (x86)\EventGhost\plugins\GameVoice
21:58:06: 0 MainThread: missing guid in plugin: C:\Program Files (x86)\EventGhost\plugins\Ping
21:58:07: 0 MainThread: PluginManager.ScanAllPlugins :1.7063028024695837
21:58:07: 0 MainThread: SendKeysParser.__init__()
Error in sys.excepthook:
File "C:\Program Files (x86)\EventGhost\eg\Core.py", line 352, in TracebackHook
eg.log.PrintTraceback(excInfo=(tType, tValue, traceback))
AttributeError: 'NoneType' object has no attribute 'log'
Original exception was:
File "EventGhost.pyw", line 51, in <module>
import eg
File "C:\Program Files (x86)\EventGhost\eg\__init__.py", line 91, in <module>
import Core
File "C:\Program Files (x86)\EventGhost\eg\Core.py", line 384, in <module>
eg.Init.Init()
File "C:\Program Files (x86)\EventGhost\eg\Init.py", line 74, in Init
import WinApi.COMServer
File "C:\Program Files (x86)\EventGhost\eg\WinApi\COMServer.py", line 78, in <module>
RegisterClasses(EventGhostCom, quiet=True)
File "win32com\server\register.pyc", line 430, in RegisterClasses
File "win32com\server\register.pyc", line 232, in RegisterServer
File "win32com\server\register.pyc", line 49, in _remove_key
pywintypes.error: (87, 'RegDeleteKey', 'The parameter is incorrect.')
The above means nothing to me so any help would be most appreciated. I'm so stuck with this that I've already trialled EventGhost alternatives but I'd hate having to redo all my macros...
Thanks!!
robimart
Instant crashes on Windows 10 (log attached)
Re: Instant crashes on Windows 10 (log attached)
Did you try to uninstall it and then reinstall it?
Yes, I've tried that twice - no luck!
Any other tips?
robimart
Any other tips?
robimart
OK - I've managed to fix the problem.
I uninstalled and reinstalled to a *different directory* and for whatever bizarre reason it now works!
Glad to have EG back
robimart
robimart
