Hi I just upgraded to windows 10 64 bit from win 7 64bit and I can't get EG to run on startup. I have to manually run it each time.
I have tried the following:
1) Added EG to startup folder
2) Made a *.bat file to run EG and added that to the startup folder.
In each case no success. Anyone have a solution? Thanks.
Windows 10 and Eventghost on Startup
Re: Windows 10 and Eventghost on Startup
Hi!
Im using windows 10.
What I did and its working for me is to change the standard program for "xml" files, the file you save your setup as, and chose eventghost as standard program. Then create a shortcut to that file and put in autostart folder.
You mean you set eventghost as the program to open xml file? then it worked?r1kkie wrote:Hi!
Yes and put a shortcut of your <name of your file.xml> in the autostart folder.
There is a setting in eventghost to run it on startup but then for me it will load the example.xml config that's i located in the program folder.
