Is there any way to identify a program when finished ?
mparadiso
Post by mparadiso »
I wonder if there is any way to know when a program is shut.
I'm using Pulse-Eight with EventGhost and Kodi.
When I run Kodi, it fails to identify the Pulse Eight because EventGhost are using it. With this remote does not function.
I found a way to solve this was to disable the plugin Pulse Eight before running Kodi and enable when you leave.
In this case one OnClose method that can be executed when the Kodi is finalized would help me to be able to enable this plugin automatically.
I do not know if this is the best solution or whether there is any alternative to this problem. But initially was the solution found to solve this.
Thanks.
Re: Is there any way to identify a program when finished ?
mparadiso wrote:I found a way to solve this was to disable the plugin Pulse Eight before running Kodi and enable when you leave.
If you are using the XBMC2 plugin (or if not) you can activate Kodi notifications (events) that send an OnQuit event when Kodi quits that you can use.
Or if you use the EventGhost start application to run Kodi, you can activate the "Trigger event when application is terminated".
Or you can use one of these plugins "Task Create/Switch Events" or "Process Watcher", as they generate events when programs starts or ends.
Hopefully this is enough for you. :D
joni
