Hi, I do a "Sleep" for My PC: press the button and the PC will be switched off in 30 minutes (for example)...
I use TriggerEvent, but what if I started TriggerEvent for 30 minutes, and then changed my mind. how to stop the timer?
How to Stop TriggerEvent?
- Neytrino-OnLine
Sin┬®erely yours, Neytrino.
Re: How to Stop TriggerEvent?
Use the 'disable an item' action would be one way.
Or you can search for the sleep timer plugin which cycles through to 'off/disabled' from memory.
- Neytrino-OnLine
Thanks, I found this topic and use EggTimer...blaher wrote:Or you can search for the sleep timer plugin which cycles through to 'off/disabled' from memory.
