Lights and electrical equipment control with EG
bxr
Post by bxr »
Looking for reliable, fast, preferably controlled from EG lights control.
1. Specs needed: 220/230V, wireless or on electric wires (i.e Z-wave etc.).
2. Preferably small units as my switches 'holes' are round (rather than squared).
3. Allows to control the light from local switch as well (and 3-way, i.e two switches).
4. Controlled from EG is a big plus.
4. Cost is less the issue but reasonable.
Any recommendations?
Re: Lights and electrical equipment control with EG
Which country are you in? Z-Wave is region specific.
I use Z-Wave with a Vera and various devices that meet all your criteria. EG interfaces with Vera pretty well.
bxr
Post by bxr »
Israel. I saw there are no compatible devices on Z-Wave site (?) but I read the frequency approved here is 916 MHz.
Most recommended brands or products?
Also, is there a z-wave IR blaster for eventghost?
Other options I found:
Philips hue (from some applications).
Apple HomeKit compatible devices.
Do you have RF devices in Israel?
If so, a good choice (and much cheaper than z-wave) is to use devices like this
http://www.homeeasy.eu/Receivers/
To control them from EG you need a transceiver like the RFXtrx433
http://www.rfxcom.com/epages/78165469.s ... nsceivers
But it all depends on availability and if they are approved for use in Israel
bxr
Post by bxr »
Yep.
I think RF over 433 Hz is allowed.
I thought of:
http://www.coco-technology.com/en/home/
or
'plc' bus equipment that I can buy locally (I do use Ethernet over electrical cables between floors so it might interrupt?).
The COCO products can be used but the control station is to my knowledge not supported by EventGhost. Therefore I strongly suggest to use the RFXtrx433 that has an EventGhost plugin and is supporting COCO Technology devices.
Problem with Z-Wave is the frequencies used are different based on what region of the world you live in. and to then specify a round hold for the actual switch..... eeerrr.... that's kinda pushing it. But also has to be 220 to 240 volt. I have seen a lot of the Z-Wave devices made to date. and I can't recall a single one that meets those parameters.
in the plugin support forum is a newer version of the Vera plugin, at the moment it only does the lights but i have been using it for several days now and it seems stable and doesn't stop working after a day or so like the old plugin.
If i happen to see something I will post in here again. but that's gonna be a hard one without possibly modifying an existing device to fit what you need.
K
