SmartThings SmartApp: Send Events to EventGhost
luma
Post by luma »
I wrote a SmartThings SmartApp to send events from SmartThings to an EventGhost system running the Webserver plugin. SmartThings devices such as light switches, smart bulbs, motion sensors, thermostats, contact sensors, door locks, moisture sensors, and more can be selected within the SmartApp to send device events to EG. The result looks something like this in EG:
The SmartApp looks like this:
Image Image Image
purp
Re: SmartThings SmartApp: Send Events to EventGhost
Post by purp »
This is very usefull! Thank you!
purp
Post by purp »
luma wrote:I wrote a SmartThings SmartApp to send events from SmartThings to an EventGhost system running the Webserver plugin. SmartThings devices such as light switches, smart bulbs, motion sensors, thermostats, contact sensors, door locks, moisture sensors, and more can be selected within the SmartApp to send device events to EG. The result looks something like this in EG:
Do you know if its possible to send events from eventghost to ST?
[email protected]
Post by [email protected] »
Hey there I need help implementing this. Where do I put the code and what do I do on the smart things hub
