LaMetric with EG
User1306
LaMetric with EG
Post by User1306 »
HI Guys
i backed a project on Kickstarter Called LaMetric. it's basiclly an LED display that shows all kind of info from different sources.
it can display a couple of letter (i think around 12) and an icon image in RGB colors. please have a look https://lametric.com
they have a developer platform so you can create your own feed and send whatever text you want to the device, its a neat idea and i think with the power of eventghost you can do quite a lot with it.
if you create an account on (https://lametric.com/creators) (it will take less than a minute) then you can create your own feeds
they provide you with a simple code, i'm try to turn this code into Python script and have the text field fed with different info from EG, but for some reason i keep getting errors when i try to test it. the code i modified is below, please have a look and let me know why its not working?
this is the sameple code they give you
curl -X POST \
-H "Accept: application/json" \
-H "X-Access-Token: [MY-TOKEN]" \
-H "Cache-Control: no-cache" \
-d '{
    "frames": [
            "index": 0,
            "text": "xxx",
            "icon": "a87"
https://developer.lametric.com/api/V1/dev/widget/update/com.lametric.(API)/1
and this is my code turned into Python
import requests
headers = {
    'Accept': 'application/json',
    'X-Access-Token': 'MY-TOKEN',
    'Cache-Control': 'no-cache'
payload = {
    "frames": [
            "index": 0,
            "text": "<TEXT FROM EG GOES HERE>",
            "icon": "null"
requests.post('https://developer.lametric.com/api/V1/dev/widget/update/com.lametric.(API)/1', headers=headers, json=payload)
if anyone have any clue please let me know, maybe in the future we could create a plugin, it's very handy at displaying quick info
Thank you in advance
Re: LaMetric with EG
What kind of error you get?
You used the latest version EventGhost?
User1306
Post by User1306 »
thanks for taking a look at it. below is the error i get (i just removed my API)
Python script "2", line 19, in <module>
requests.post('https://developer.lametric.com/api/V1/d ... tric.(API)', headers=headers, json=payload)
File "C:\Program Files (x86)\EventGhost\lib26\site-packages\requests\api.py", line 88, in post
return request('post', url, data=data, **kwargs)
File "C:\Program Files (x86)\EventGhost\lib26\site-packages\requests\api.py", line 44, in request
return session.request(method=method, url=url, **kwargs)
TypeError: request() got an unexpected keyword argument 'json'
the Eg version i have is this (0.4.1.r1700)
thanks
Edit: i just saw there's a new version, i will update it now and try again
Edit 2: after updating (r1706) i still have the same issue
Here I see bug:
User1306 wrote:requests.post('https://developer.lametric.com/api/V1/d ... tric.(API)', headers=headers, json=payload)
It is likely to be as follows:
requests.post('https://developer.lametric.com/api/V1/dev/widget/update/com.lametric.(API)', headers=headers, data=payload)
User1306
Post by User1306 »
Thank you very much for your reply Pako.
i actually had it set to Data at first and it didnt not work, i checked with LaMetric support and they suggested to make switch it to json.
the good news i'm not getting an error in EG anymore, the bad it's not displaying the message. i need to figure out if its from my code or their end.
Doktor J
Post by Doktor J »
You could try making your payload a string, e.g.
egoutput = "<DATA FROM EG GOES HERE>"
payload = """{
    "frames": [
            "index": 0,
            "text": "%s",
            "icon": null
}""" % (egoutput)
In my PHP script I found it played much nicer when I stringified the JSON and kept it pretty-printed. Note that, when stringified, "null" should not be in quotes if you want no icon.
DISCLAIMER: I haven't used EventGhost, and am a bit rusty on my Python. I'm a new LaMetric app developer, and discovered that they're very fussy about the JSON formatting.
Doktor J
Post by Doktor J »
I actually just wrote a Python push script for my LaMetric (inspired by your post!) and confirmed that stringified, pretty-printed JSON seems to be happy:
import json
import requests
# Put in your access token of course
headers = {
    'X-Access-Token': '',
# Your code that gets data and puts it into JSON goes here
payload = json.dumps(myJSONVar, indent=4, separators=(",", ": "))
# Your app ID and version should go here, e.g. "com.lametric.abcdefabcdef12341234" and "3"
appid = "xxxxxxx"
ver = "3"
try:
    q = requests.post("https://developer.lametric.com/api/V1/dev/widget/update{0}/{1}".format(appid, ver), data=payload, headers=headers)
except (ConnectionError, HTTPError, Timeout, TooManyRedirects) as e:
    print "Error {0}: {1}".format(e.errno, e.strerror)
    pass
    print q
Of course you can knock off the "else" part of the try if you don't need it to print the output; otherwise you should get <200 success> as your output.
User1306
Post by User1306 »
Thank you very much for checking it out. i'm very new to python my self too, so no worries.
i tried your code but i'm getting a 404 response.
this is the complete code without Token and app ID
import json
import requests
headers = {
    'X-Access-Token': 'xxxxxx',
egoutput = "Testing123"
myJSONVar = """{
    "frames": [
            "index": 0,
            "text": "%s",
            "icon": "a1036"
}""" % (egoutput)
appid = "com.lametric.xxxxxxxxxx"
ver = "1"
try:
    pass
    print q
how did you parse the JSON exactly?
really appreciate your help, i'm looking forward to be able to send all kind of info to LaMetric
Edit: i realized their site is acting super slow and sometimes just hangs there, dunno if that's related
Edit 2:
Turning the json into string like you mentioned first with the code i posted did the trick :).
that's good enough for now.
thanks for your help
