The main product page for Eventghost indicates that support for the RW-II is 'planned' (The RW-I and RW-Plus are X-10 devices and therefore natively supported; the RW-II is a Phillips device that apparently doesn't use the X-10 driver but a special one).
Does anyone know if there is a plugin available for the RW-II? Would be very much appreciated.
Cheers and thanks,
The REAL Joe Blow
ATI Remote Wonder II
Re: ATI Remote Wonder II
if it is a Phillips based device then it might be USB HID based? If it is USB HID based then support for it should be pretty easy. let me know if you want help figuring out if it is USB HID based remote.
Melloware Inc.
EventPhone iPhone Application
Melloware Inc.
- Bitmonster
I just found an RW-II in my postbox, that I bought at eBay. There is an SDK from ATI to build custom plug-ins for their control software, so it should be possible to use this device with EG. The downside is, that you will have to use two applications (EG and the ATI software) and two plug-ins (one for EG and one for the ATI software). If I have some time and feel like doing it, I will try to build the plug-ins.
- Bitmonster
