Control Roomba with EG with USB uirt!
kalinkamaen
Post by kalinkamaen »
Hello guys.
I couldnt see any topic about this subject, so I wanted to tell my experience.
I have manged to controll my Roomba 583 with EG with USB uirt. I found a text file
on a other forum with some IR codes. I copy and pasted them directly into USBuit
plugin on EG. Here is the codes:
TITLE= Roomba
UP=Up
0000 0069 0000 0008 0070 0027 0023 0070 0023 0070 0023 0070 0023 0070 0023 0070 0070 0027 0023 030B
LEFT=Left
0000 0069 0000 0008 0070 0027 0023 0070 0023 0070 0023 0070 0023 0070 0023 0070 0023 0070 0070 02C8
RIGHT=Right
0000 0067 0000 0008 0072 0024 0024 0072 0024 0072 0024 0072 0024 0072 0024 0072 0072 0024 0072 02D0
CIRCLE=Spot
0000 0067 0000 0008 0074 0024 0024 0074 0024 0074 0024 0074 0024 0074 0074 0024 0024 0074 0024 0314
CROSS=Clean
0000 0069 0000 0008 0071 0027 0023 0071 0023 0071 0023 0071 0071 0027 0023 0071 0023 0071 0023 030B
TRIANGLE=Dock (MAX?)
0000 0069 0000 0008 0070 0027 0024 0070 0024 0070 0024 0070 0024 0070 0070 0027 0024 0070 0070 02C8
L_SQUARE=Power off
0000 0069 0000 0008 0070 0027 0023 0070 0023 0070 0023 0070 0070 0027 0023 0070 0070 0027 0023 030B
L_TRIANGLE=Pause
0000 0069 0000 0008 0070 0023 0023 0070 0023 0070 0023 0070 0070 0023 0023 0070 0023 0070 0070 02C8
To make roomba clean, you need to send this clean signal 3 times. And my best result has been sending first 3 pause signals and then 3
clean signals.
It seems like sometimes the roomba are in some kind of state that only clean signal is not good enough.
PS: you IR sender must be close to Roomba.
Here is one example:
I hope this is helpfull for someone!
SupahNoob
Re: Control Roomba with EG with USB uirt!
Post by SupahNoob »
That's very neat! It makes me wish my residence was small enough to make use of a Roomba now!
kalinkamaen
SupahNoob wrote:That's very neat! It makes me wish my residence was small enough to make use of a Roomba now!
You can buy many units as I did ;)
