Pushbullet client make a "Task.Deactivated.Kodi"
nonob
Post by nonob »
I use EG to control both my kodi and mediamonkey app.
I use the "Task.Activated" events to toggle exclusive activation to one or the other : "Task.Activated.Kodi" force exclusive control for Kodi and "Task.Desactivated.Kodi" go back to exclusive mediamonkey control.
Lats days, i installed the windows desktop app "pushbullet client" and since, i lose control of Kodi when i play a video, because (i d'ont know why) pushbullet create an event "Task.Created.pushbullet_client" that is follow by the event "Task.Desactivated.Kodi" and so, i lose my Kodi control.
When this occure, i didn't see anything on my screen (no pushbullet windows for instance).
This is the event chen the pb happen :
MceRemote.Mce.Ok
   Select
      XBMC2 #2: Select
Task.NewWindow.pushbullet_client
   Activation exclusive: MediaMonkey
Task.Activated.pushbullet_client
Task.Deactivated.pushbullet_client
Task.ClosedWindow.pushbullet_client
Task.Destroyed.pushbullet_client
MceRemote.SIRC12.0813
MceRemote.SIRC12.0812
MceRemote.Mce.Right
MceRemote.Mce.Right
MceRemote.Mce.Right
MceRemote.Mce.Right
MceRemote.Mce.Left
MceRemote.Mce.Up
MceRemote.Mce.Down
MceRemote.Mce.Right
MceRemote.Mce.Right
MceRemote.Mce.Right
MceRemote.Mce.Left
MceRemote.Mce.Left
MceRemote.Mce.Right
MceRemote.Mce.Right
MceRemote.Mce.Stop
   Stop
      MediaMonkey: Stop
MceRemote.Mce.Stop
   Stop
      MediaMonkey: Stop
System.UnIdle
Task.ClosedWindow.Kodi
Task.Destroyed.Kodi
Task.Activated.Desktop
Task.Deactivated.Desktop
System.Idle
System.ClipboardChanged
System.UnIdle
Task.Activated.EventGhost
What can i do to solve it ?
SupahNoob
Re: Pushbullet client make a "Task.Deactivated.Kodi"
Post by SupahNoob »
I'm confused .. can you show me your setup of this description? Please take a screenshot of this, or right click the macro (little orange gear icon) and select "copy" and then paste the result into your post response.
nonob
Post by nonob »
Hi :)
This is a copy of my macro for Kodi exclusive control :
<EventGhost Version="1710">
    <Macro Name="Activation exclusive: XBMC2 #2" Expanded="True">
        <Event Name="Task.Activated.Kodi" />
            MediaMonkey.Stop()
            EventGhost.EnableExclusive(XmlIdLink(476))
and this is a copy of my macro for Mediamonkey exclusive usage :
    <Macro Name="Activation exclusive: MediaMonkey" Expanded="True">
        <Event Name="Task.Deactivated.Kodi" />
            EventGhost.EnableExclusive(XmlIdLink(1324))
SupahNoob
Post by SupahNoob »
So, if I understand correctly ...
1) You've set up for when Kodi is deactivated, MediaMonkey is given the topmost window priority.
2) You've set up for when MediaMonkey is deactivated, Kodi is given the topmost window priority.
3) You installed Pushbullet (the Windows app) and it creates windows quickly, effectively deactivating either program above.
* You, as of right now, DON'T WANT to react to Pushbullet window activations.
Does this sound correct overall?
nonob
Post by nonob »
Hi :)
1 : Mediamonkey is given "exclusive activation" through eventghost
2 : Kodi is given "exclusive activation" through eventghost
What i mean by "exlusive activation" :
3 : I don't want and don't understand why Pushbullet create "task events" when it is minimized and inactive (no notifications).
