How to use this event
eirik226
Post by eirik226 »
Well, you can pretty much see what my problem is, I feel like i've tried it all, and no idea what to do. It's probably stupidly easy right..?
Thanks in advance if you know this and can help.
Re: How to use this event
Have you tried to drag & drop the event from the log on the left side to the macro on the right side?
It should look like this to work I think
When you're going to do, how krambriw advice (drag & drop the event from the log on the left side to the macro on the right side),
then you will see that the event suffix, it is only ClientMessage.
Everything else (what follows this string), it is the event payload.
Note:
If you need for example the string "TV_OFF" to use as an event suffix, you can use a simple converter:
eirik226
Post by eirik226 »
I've tried what you said Walter and it does not work.
The problem using that way Pako is that I have 2 - TV_ON and TV_OFF, and I will probably add a lot more these coming weeks. So I can't use 1 event to trigger them all, that would make a mess of things If i understand everything correctly.
But anyway, the way you said Walter did not work.
Edit: I found out I can use your way Pako - I just need to add the events the macro you showed me create to the correct places, thank you! :)
