First I want to say that your software are great.
The greffon Task Create/Switch Events do not report the events of a software 64 bit.
The action Find Windows works but not with the name of the program (find all the info but not the name of program)
I am under Windows Vista Ultimate 64 Bit for information and the software not detected is MPC home Cinema X64.
I hope you can do something.
Excuse my poor english but i'm french.
[FIXED] Problem with Task plugin when using x64 software
Re: Problem with greffon Task Create/Switch Events with soft x64
With this settings i can find the window and send keystrokes to it.
Thanks for this reply, it works great.
Only the probleme of the Task Create stay.
- Bitmonster
Re: [OPEN] Problem with Task plugin with soft x64
Uff, this will be hard to fix. It has something to do with the emulation of x32 programs in x64 environments.
- Bitmonster
Please try 0.3.6.1328 and report your findings.
Re: [OPEN] Problem with Task plugin when using x64 software
With .1328 the task de/activation show up in the log (didn't with .1326) on my PC.
Task.Activated.mplayerc
Task.Deactivated.mplayerc- Bitmonster
FindWindow should also be able to identify the process name.
In the last version, this problem are fix.
It's great.
Thanks for your quick reaction.
It's great.
