Cancel action if another event happens within 1 minute
r_persater
Post by r_persater »
Hi folks!
Anyone out there that can give me a solution to this: I want to send a message some time (say a minute) after an event has occurred, but not if another event occurs before the minute has passed. More specifically, if my phone disappears from the wifi, and doesn't reappear within a minute, it should trigger an action. But if it shows up again the action is cancelled. (My phone make micro breaks from the wifi, like a few seconds or so, very often.) Glad if someone can come up with some ideas to try out!
/Rickard
piert
Re: Cancel action if another event happens within 1 minute
Post by piert »
I think I have used the timer plugin (I believe it is Pako's) for similar scenarios, because it has a feature to cancel running timers by the same name.
Or you can disable / enable folders in conjunction with the timer plugin, so your event will fire on disconnect, but the action won't be performed because the folder is disabled, until your minute has passed, and then the folder is enabled.
