Stop currently playing sound
skribb
Post by skribb »
Is there a way to Stop currently playing sound within EG? thanks :D
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
Re: Stop currently playing sound
From what source?
skribb
Post by skribb »
blaher wrote:From what source?
eventghost:
system > sound card > play sound
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
You could press mute using the same part of EventGhost, but I'm not sure how to abort it there. You could always use another external program that can be controlled like winamp, or foobar, and stop it instead.
skribb
Post by skribb »
blaher wrote:You could press mute using the same part of EventGhost, but I'm not sure how to abort it there. You could always use another external program that can be controlled like winamp, or foobar, and stop it instead.
Well I have tried with AutoHotkey which would be the most ideal solution but I can't make sound work there for some reason. i don't fancy the idea of having to open a program with a UI just to play a sound file. :cry:
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
I suggest you use CrystalWolf Audio Player. This is a very small, but very good audio player.
Remarks :
  • The path to the file to be played can be specified as Command line options:. It can be also "{eg.event.payload}" (including the quotation marks !).
  • In the combo box you can select Window options: Minimized, so it can be invisible.
skribb wrote:i don't fancy the idea of having to open a program with a UI just to play a sound file. :cry:
If it is a big problem, you can use (for example) command line player DLC.
Note:
Command line options may be, for example -w "{eg.event.payload}" (including the quotation marks !).
Contents of Python Script:
from win32com.client import GetObject
from win32api import OpenProcess, TerminateProcess, CloseHandle
PROCESS_TERMINATE = 1
WMI = GetObject('winmgmts:')
processes = WMI.InstancesOf('Win32_Process')
p = WMI.ExecQuery('select * from Win32_Process where Name="dlc.exe"')
pid = p[0].Properties_('ProcessId').Value
handle = OpenProcess(PROCESS_TERMINATE, False, pid)
TerminateProcess(handle, -1)
CloseHandle(handle)
skribb
Post by skribb »
Thank you for the tips
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
skribb wrote:Thank you for the tips
This is obviously intended for all users who will solve a similar problem.
It would be nice if you posted your final solution.
skribb
Post by skribb »
I like the way you think.
Concerning my solution, I always have like 100 projects simultaneously, so I probably won't get thru with this for several months :P My automation setup is growing all the time, so much to keep track of :roll:
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
