RME HDSP 9632 + logitech K310: Volume Control
Appendix
Post by Appendix »
Hi guys... i hope my question will not considerd stupied..
i really tried to dig into this issue and figure out by myself about how to do it
but with no luck.. i even not sure if it possible.. the answers i found about it
r so confusing..
so that's the issue: i got RME HDSP 9632 soundcard in my pc who is
defined as the only soundcard that active (default) + i use the logitech K310 keyboard for my pc.
my question is simple: can i control the volume up/down of the RME soundcard via the F10 and F11 keys
on my logitech keyboard ?
if yes.. how can i do it ? how do i take control on the "TotalMix" (the RME's interface)..
whice plugin i need to load in the EventGhost.. which macro.. which action...
hope some1 can help me..
Thanx in advanced...
S.
