Read string for change and re-send string from Serial Port
Wilson2517
Post by Wilson2517 »
I have a serial port read any string.
I want use phyton for capture regex and active a Variable, but I dont now to do make the code.
for example this is the string
Serial.iPhoneFer_Online
Ineed only capture Fer and active variable to true, but I need condition for this, IF Online fire command and IF Offline fire other command.
Best Regards :D
Re: Read string for change and re-send string from Serial Po
ok so you just want to set a variable to true or false depending on the event???
what i need. i need the events and payloads that you are wanting to make into a bool variable
and i am not sure what you want to do with regex and the serial port.
you have to be very detailed and specific that way i can get the right thing going for you
Wilson2517
Yes, I want this.
The string is iPhoneFerOnline, on the log could be Serial.iPhoneFerOnline.
So could be
var StatusUpdate = false
IF (var StatusUpdate == true){
Serial.Write("Update_Ready")
}else {
Serial.Write(No_Update)
for example I know the code is diferent.
what is setting the StatusUpdate variable?
the event you are saying is something that is posting already into eventghost???
i can do the code easily but i need to know what event will set the variable True, and what event will set it False
and you also have to have the serial plugin installed for this to work
