Qivivo thermostat with PHP Plug in
azertyuiop
Post by azertyuiop »
Good day,
I have a Qivivo thermostat that drives my home heating device and I would like to connect it with EventGhost.
Someone wrote a PHP plugin to access Qivivo thermostat data : https://github.com/WoodySlum/QivivoBridge.
Is it possible to 'load' this plugin into EG and then use it ? and if yes, how ?
It may also be possible to re-write this plugin in Python but it seems way beyond my programming skills for the time beeing...
Thanks in advance for any advice you may have,
Olivier
azertyuiop
Re: Qivivo thermostat with PHP Plug in
Well, I finalelly get what I wanted even if it's not the nicest way to do it I guess...
I installed XAMPP and ran the Apache server on a different port than the EventGhost webserver.
I created GetThermostatStatus.php file in the C:\xampp\htdocs directory, based on code of here above link (copy/paste I'd rather say).
<?php
class Qivivo {
	private $qivivoLogin = "[email protected]";
	private $qivivoPassword = "my_password";
	private $credentials = NULL;
	private $thermostatStatus = NULL;
	private $urlGetLogin = "http://www.qivivo.com/login";
	private $urlLogin = "http://www.qivivo.com/login_check";
	private $urlThermostatStatus = "http://www.qivivo.com/myQivivo/updateRealTime";
	private $urlThermostatSetTemperature = "http://www.qivivo.com/myQivivo/temps-reel/setTemperature";
	private $urlAccount = "http://www.qivivo.com/mon-compte/mes-produits";
	private $dailyUsage = "http://www.qivivo.com/myQivivo/synthese/day";
	private $singlePageAuth = false;
	private $enableLog = false;
	function __construct($login, $password) {
		$this->qivivoLogin = $login;
		$this->qivivoPassword = $password;
		if ($this->qivivoLogin == "") {
			$this->error(703, "No username param");
		if ($this->qivivoPassword == "") {
			$this->error(704, "No password param");
	function __destruct() {
	private function error($code, $message) {
		die("[".$code."] ".$message.PHP_EOL);
	private function log($log, $level) {
		if ($level < 5 && $this->enableLog) {
			echo $log.PHP_EOL;
	function getAccountInfo() {
		$this->connect();
		$ch = curl_init($this->urlAccount);
		curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
		curl_setopt($ch,CURLOPT_POSTFIELDS, $fields_string);
		curl_setopt($ch, CURLOPT_HTTPHEADER, array("Cookie: ".$this->buildCookie(), "Host: www.qivivo.com"));
		curl_setopt($ch, CURLOPT_REFERER, "http://www.qivivo.com/myQivivo/");
		$result = curl_exec($ch);
		preg_match_all("/(<li>Niveau des piles : )(.*)(%<\/li>)/m", $result, $battery);
		$infos = new StdClass();
		if (count($battery) == 4) {
			if ($battery[2][0] != "") {
				$infos->battery = intval($battery[2][0]);
		preg_match_all("/(<li>Num├®ro de s├®rie : )(.*)(<\/li>)/m", $result, $serial);
		if (count($serial) == 4) {
			$infos->serial = $serial[2][0];
		preg_match_all("/(<li>Version Firmware : )(.*)(<\/li>)/m", $result, $firmware);
		if (count($firmware) == 4) {
			$infos->firmware = $firmware[2][0];
		preg_match_all("/(<li>Dernière transmission : )(.*)(<\/li>)/m", $result, $lastTransmission);
		if (count($lastTransmission) == 4) {
			$infos->lastTransmission = $lastTransmission[2][0];
		return $infos;
	private function connect() {
		if ($this->credentials == NULL) {
			$this->getCredentials();
		if ($this->thermostatStatus == NULL) {
			$this->getThermostatInfo();
	private function getCredentials() {
		$this->log("Getting credentials", 4);
		$bCookie = "qivivo=abc";
		if (!$this->singlePageAuth) {
			$ch = curl_init($this->urlGetLogin);
			curl_setopt($ch, CURLOPT_HEADER, 1);
			preg_match_all('/^Set-Cookie:\s*([^;]*)/mi', $result, $baseCookie);
			$bCookie = "";
			if (count($baseCookie) > 1) {
				for ($i = 1 ; $i < count($baseCookie) ; $i++) {
					$bCookie .= $baseCookie[$i][0].";";
			$bCookie = rtrim($bCookie, ";");
		// Retrieve csrf token
		preg_match_all("/( name=\"_csrf_token\" value=\")(.*)(\")/m", $result, $csrfData);
		if (count($csrfData) == 4) {
			if ($csrfData[2][0] != "") {
				$csrf = $csrfData[2][0];
		$this->log("Qivivo csrf token : ".$csrf, 3);
		$ch = curl_init($this->urlLogin);
		$fields = array(
			'_csrf_token' => urlencode($csrf),
			'_username' => urlencode($this->qivivoLogin),
			'_password' => urlencode($this->qivivoPassword)
		$fields_string = "";
		foreach($fields as $key=>$value) { $fields_string .= $key.'='.$value.'&'; }
		$fields_string = rtrim($fields_string, '&');
		// curl_setopt($ch,CURLOPT_USERAGENT,'Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.13) Gecko/20080311 Firefox/2.0.0.13');
		curl_setopt($ch,CURLOPT_HTTPHEADER,array('Origin: http://www.qivivo.com',
			'Referer: http://www.qivivo.com/login',
			'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8',
			'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/46.0.2490.86 Safari/537.36',
			'Upgrade-Insecure-Requests: 1',
			'Accept-Encoding: gzip, deflate',
			'Accept-Language: fr,en-US;q=0.8,en;q=0.6,fr-FR;q=0.4',
			'Cookie: '.$bCookie
		//'Cookie: compatEnergy=gaz; compatTHMarque=delta-dore; cookieCompatibility=true; __utma=; __utmc=; __utmz=utmccn=utmcmd=referral|utmcct=/; _gat=1; PHPSESSID=; PRUM_EPISODES=s=&r=http%3A//www.qivivo.com/login'
		$this->log(str_replace(">", "]", str_replace("<", "[", @$result)), 5);
		// get headers too with this line
		curl_setopt($ch,CURLOPT_POST, count($fields));
		// get cookie
		// multi-cookie variant contributed by @Combuster in comments
		preg_match_all('/^Set-Cookie:\s*([^;]*)/mi', $result, $matches);
		// var_dump($result);die;
		$this->credentials = array();
		foreach($matches[1] as $item) {
		    parse_str($item, $cookie);
		    $this->credentials = array_merge($this->credentials, $cookie);
		$this->log("Credentials retrieved : ".implode(" / ", $this->credentials), 5);
		if (count($this->credentials) == 0) {
			$this->error(701, "Could not load credentials", false);
		$this->log(str_replace(">", "]", str_replace("<", "[", $result)), 5);
	private function buildCookie() {
		$ret = "";
		foreach ($this->credentials as $key => $value) {
			$ret .= $key."=".$value.";";
		$ret = rtrim($ret, ";");
		return $ret;
	private function getThermostatInfo() {
		$this->log("Retrieve thermostat info", 4);
		$ch = curl_init($this->urlThermostatStatus);
		curl_setopt($ch, CURLOPT_HTTPHEADER, array("Cookie: ".$this->buildCookie()));
		if (!$result) {
			$this->error(702, "Could not retrieve thermostat data");
		$this->log(str_replace(">", "]", str_replace("<", "[", $result)), 4);
		$this->thermostatStatus = json_decode($result);
	function getInsideTemperature() {
		$this->connect();
		$this->log("Retrieve thermostat inside value : ".@$this->thermostatStatus->getData->temperatureIn, 4);
		return @$this->thermostatStatus->getData->temperatureIn;
	function getOutsideTemperature() {
		$this->connect();
		$this->log("Retrieve thermostat outside value : ".@$this->thermostatStatus->getData->temperatureOut, 4);
		return @$this->thermostatStatus->getData->temperatureOut;
	function getRequestedTemperature() {
		$this->connect();
		$this->log("Retrieve thermostat requested value : ".@$this->thermostatStatus->getData->tcons, 4);
		return @$this->thermostatStatus->getData->tcons;
	function getThermostatStatus() {
		$this->connect();
		$this->log("Thermostat status : ".@$this->thermostatStatus->getData->getAllData->heating_status, 4);
		return $this->thermostatStatus->getData->getAllData->heating_status;
	function setTemperature($value) {
		$this->connect();
		$this->log("Trying to set temperature : ".$value, 1);
		$value = str_replace(",", ".", $value);
		if (!is_numeric($value)) {
			$this->error(705, "Param error in set temperature");
		$this->log("Set temperature : ".$value, 1);
		$fields = array(
			't_ideal' => urlencode($value)
		$ch = curl_init($this->urlThermostatSetTemperature);
		$res = json_decode($result);
		if ($res->success->state != "success") {
			$this->error(706, "Could not set temperature");
		} else {
		return $this->thermostatStatus->getData->getAllData->info_message;
	function getMode() {
		$this->connect();
		$plannings = json_decode($this->thermostatStatus->getData->plannings);
		$currentPlanning = @$plannings->current_planning;
		$ret = "unknown";
		foreach (@$plannings->plannings as $planning) {
			if ($planning->id == $currentPlanning) {
				$ret = $planning->name;
				break;
		return $ret;
<html>
<head></head>
<body>
<?php
$thermostat = new Qivivo("[email protected]", "my_password");
//<br/>
?>LivingRoomTempe:<?php
$inTemperature = $thermostat->getInsideTemperature();
//var_dump($inTemperature);
echo $inTemperature;
TargetTemperature:<?php
$reqTemperature = $thermostat->getRequestedTemperature();
echo $reqTemperature;
OutsideTemperature:<?php
$outTemperature = $thermostat->getOutsideTemperature();
echo $outTemperature;
ThermostatStatus:<?php
$status = $thermostat->getThermostatStatus();
echo $status;
ThermostatMode:<?php
$mode = $thermostat->getMode();
echo $mode;
<?php
//AccountInfo :
//$aInfos = $thermostat->getAccountInfo();
//echo $aInfos;
</body>
</html>
I installed WGET for Win32 from http://gnuwin32.sourceforge.net/packages/wget.htm
Then in EG, I created a macro based on Pako code from viewtopic.php?f=2&t=5046 (yeah, also a copy/paste : I'm good at that ;-))
eg.result = None
from subprocess import Popen, PIPE, STDOUT, SW_HIDE
def popen(cmd):
    proc = Popen(cmd.split(),stdout = PIPE,stderr = STDOUT,creationflags = SW_HIDE, shell = True)
    data = proc.communicate()[0]
    return (proc.returncode, data)
ret, data = popen("call chcp") #DOS console codepage
if not ret:
    cp = "cp" + data.split()[-1]
    ret, data = popen("C:\\Progra~1\\GnuWin32\\bin\\wget.exe -q -O - '$@' localhost:7301/Test.php")
    if not ret:
        result = data.decode(cp)
        result = result.split(',')
        eg.globals.tempe_in_thermostat = result[0].rsplit(':')[1]
        eg.globals.tempe_tgt_thermostat = result[1].rsplit(':')[1]
        eg.globals.tempe_out_thermostat = result[2].rsplit(':')[1]
        eg.globals.status_thermostat = result[3].rsplit(':')[1]
        eg.globals.mode_thermostat = result[4].rsplit(':')[1]
        eg.Print("LivingRoomTempe = " + str (eg.globals.tempe_in_thermostat) )
        eg.Print("TargetTemperature = " + str (eg.globals.tempe_tgt_thermostat) )
        eg.Print("OutsideTemperature = " + str (eg.globals.tempe_out_thermostat) )
        eg.Print("ThermostatStatus = " + str (eg.globals.status_thermostat) )
        eg.Print("ThermostatMode =  " + str (eg.globals.mode_thermostat) )
and now, I can display these data in my HTML home page, ran on EG Web Server.
OK, I hear you, why don't I run my HTML page with XAMPP in the first place?
Well, first because I have to re write my entire page (plus, I need these data in EG),
and also because I don't know how to retreive eg.globals from there...
Do you have any suggestion for the latest?
