I just started playing with this great program with my USB=UIRT. I succefully loaded it up on an older pc to play with before I put it on my HTPC. Got working great with Meedio and ZP.
So I go to install it on my HTPC and it won't run. After just a few click anywhere I get a Not Responding error and it is a pain to shut it down.
I uninstalled and re-installed with reboots and even a new directory name. This is what I get no matter what I try as soon as it starts. None of the examples on the right pane it is blank. This is what pops up on the log.
Traceback (most recent call last) (908):
File "C:\Program Files\EventGhost3\eg\ThreadWorker.py", line 86, in DoOneEvent
File "C:\Program Files\EventGhost3\eg\ThreadWorker.py", line 31, in __call__
File "C:\Program Files\EventGhost3\eg\ActionThread.py", line 42, in StartSession
File "C:\Program Files\EventGhost3\eg\MainFrame.py", line 460, in OnAutoLoad
File "C:\Program Files\EventGhost3\eg\Document.py", line 118, in Load
File "<string>", line 45, in parse
File "<string>", line 32, in parse
SyntaxError: not well-formed (invalid token): line 1, column 3
Any ideas? Thanks!
Fresh intall of EG won't run - errors out
Re: Fresh intall of EG won't run - errors out
I am using the latest version.
I did find the issue. Not the cause of it but....
When uninstalling there is a folder left behind under /users/"user name"/apps/roaming
I deleted the evenghost folder there and then reinstalled. Worked fine this time.
