[FIXED] Install bug "user32.dll" ?????
I have successfully been running EventGhost build 1325 in Windows 2000
I thought it was time to update to 1393 but during setup I get the error as shown in the picture.
The attached log is also below.
Last version working fine for me with Windows 2000 seems to be build 1330. After this you can see that the setup file has become smaller. Was something removed from the setup???
Kind regards, Walter
  File "EventGhost.pyw", line 34, in <module>
  File "g:\EventGhost\eg\Main.py", line 130, in <module>
    import Init
  File "g:\EventGhost\eg\Init.py", line 30, in <module>
    import wx
  File "wx\__init__.pyc", line 45, in <module>
  File "wx\_core.pyc", line 4, in <module>
  File "wx\_core_.pyc", line 12, in <module>
  File "wx\_core_.pyc", line 10, in __load
ImportError: DLL load failed: The specified module could not be found.
    import Init
    import wx
    import Init
    import wx
  File "g:\EventGhost\eg\Main.py", line 129, in <module>
    e = win32com.client.Dispatch("{7EB106DC-468D-4345-9CFE-B0021039114B}")
  File "win32com\client\__init__.pyc", line 95, in Dispatch
  File "win32com\client\dynamic.pyc", line 98, in _GetGoodDispatchAndUserName
  File "win32com\client\dynamic.pyc", line 78, in _GetGoodDispatch
pywintypes.com_error: (-2146959355, 'Server execution failed', None, None)
  File "g:\EventGhost\eg\Main.py", line 135, in <module>
    eg = EventGhost(args)
  File "g:\EventGhost\eg\Init.py", line 125, in __init__
    eg.app
  File "g:\EventGhost\eg\Init.py", line 255, in __getattr__
    mod = __import__("eg.Singletons." + modName, fromlist=[modName])
  File "g:\EventGhost\eg\Singletons\App.py", line 26, in <module>
    from eg.WinApi.Dynamic import (
  File "g:\EventGhost\eg\WinApi\__init__.py", line 1, in <module>
    from Utils import PyGetCursorPos as GetCursorPos
  File "g:\EventGhost\eg\WinApi\Utils.py", line 24, in <module>
    from eg.cFunctions import GetProcessName, GetWindowChildsList
ImportError: DLL load failed: The specified procedure could not be found.
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
  File "g:\EventGhost\eg\Main.py", line 134, in <module>
    eg.app
  File "g:\EventGhost\eg\Init.py", line 252, in __getattr__
  File "g:\EventGhost\eg\WinApi\Utils.py", line 25, in <module>
    from Dynamic import (
  File "g:\EventGhost\eg\WinApi\Dynamic.py", line 933, in <module>
    WTSRegisterSessionNotification = _WtsApi32.WTSRegisterSessionNotification
  File "ctypes\__init__.pyc", line 361, in __getattr__
  File "ctypes\__init__.pyc", line 366, in __getitem__
AttributeError: function 'WTSRegisterSessionNotification' not found
    eg.app
    eg.app
    eg.app
    eg.app
    eg.app
Re: Install bug "user32.dll" ?????
Post by Bitmonster »
=>0.3.6.1397
I can confirm it works now also with Windows 2000
Thank you!
