Screamer Radio
Screamer Radio
I made new plugin. This time is it internet radio player Screamer Radio from http://www.screamer-radio.com/ .
- __init__.py
- Version 0.1.0
- (24.67 KiB) Downloaded 532 times
Re: Screamer Radio
And with my Scheduler I think you can use EG to be your alarm radio clock!
Re: Screamer Radio
Certainly, but much frequent using will probably, I think, scheduled recording.krambriw wrote:And with my Scheduler I think you can use EG to be your alarm radio clock!
Re: Screamer Radio
Only little enhancemenet.
- __init__.py
- Version 0.1.2
- (25.16 KiB) Downloaded 476 times
You know flattr ? You can
- Bitmonster
Re: Screamer Radio
Have you checked it into the SVN trunk?
Re: Screamer Radio
Now already yes.Bitmonster wrote:Have you checked it into the SVN trunk?
Fix SetVolume action -> version 0.1.3
- __init__.py
- Version 0.1.3
- (25.47 KiB) Downloaded 505 times
Re: Screamer Radio
Probably I am caused big problem in SVN.
I absolutely don't know as, SourceForge today works someways strange.
- Bitmonster
Re: Screamer Radio
Yes, you have deleted the whole trunk.
I have reverted the changes, but now you have to re-commit your plugin to the proper location.
Re: Screamer Radio
Thanks for comprehension and correction mine calamitous mistake.
Re: Screamer Radio
I get the following error while trying to load this plugin:
19:56:11 Error starting plugin: Screamer Radio
19:56:11 Traceback (most recent call last) (1431):
19:56:11 File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginInfo.py", line 299, in Start
19:56:11 File "C:\Program Files (x86)\EventGhost\plugins\ScreamerRadio\__init__.py", line 279, in __start__
19:56:11 File "xml\sax\__init__.pyc", line 33, in parse
19:56:11 File "xml\sax\expatreader.pyc", line 102, in parse
19:56:11 File "xml\sax\saxutils.pyc", line 298, in prepare_input_source
19:56:11 File "urllib.pyc", line 82, in urlopen
19:56:11 File "urllib.pyc", line 187, in open
19:56:11 File "urllib.pyc", line 199, in open_unknown
19:56:11 IOError: [Errno url error] unknown url type: 'c'
using EventGhost 0.3.6.1434 (language english UK)
any ideas?
thanks,
Antonis
any ideas?
thanks,
Antonis
Re: Screamer Radio
EventGhost probably cannot open a Language File, which is setting inside configuration file (screamer.xml).
Try this way:
1) Close EventGhost
2) Start Screamer Radio (direct - without EG)
3) Menu Settings - Language -> Select some Language
4) Close Screamer Radio
5) Start EventGhost and try Screamer Radio plugin
Try this way:
1) Close EventGhost
Re: Screamer Radio
New version (0.1.4):
- now uses AddActionsFromList
- add "On screeen menu" for choice of favorite
- __init__.py
- Plugin Screamer Radio - version 0.1.4
- (33.52 KiB) Downloaded 471 times
Re: Screamer Radio
Right now I release a new version (0.1.5) of ScreamerRadio plugin.
The main change:
I created a small program "Start_SR_Events.exe". He reads out title of ScreamerRadio windows and at each him change generates a event for EventGhost.
It is therefore very easy using the "Show OSD" to display the name of the song or station played.
To run "Start_SR_Events.exe" along with "screamer.exe" you must mark a check box in the dialog to configure plug-in.
Program "Start_SR_Events.exe" was created as a Python script and compiled by program py2exe.
Program "Start_SR_Events.exe" by itself ensure, that he will be launched only once.
For stopping (killing) of program "Start_SR_Events.exe" serve program " Stop_SR_Events.exe".
Download:
http://pako.aspone.cz/download/Start_SR_Events.exe (3409 kB)
http://pako.aspone.cz/download/Stop_SR_Events.exe (2691 kB)
The main change:
Download:
- __init__.py
- Plugin ScreamerRadio - version 0.1.5
- (38.57 KiB) Downloaded 536 times
Re: Screamer Radio
Hi
I get the folowing error when I try to start the Screamer plugin.
I use screamer 0.4.3 is that a incompatible version to the plugin?
Someone that now what that error means?
Plugin: Screamer Radio
Fel vid start av plugin: Screamer Radio
Traceback (most recent call last) (1462):
File "C:\Program\EventGhost\eg\Classes\PluginInfo.py", line 330, in Start
File "C:\Program\EventGhost\plugins\ScreamerRadio\__init__.py", line 224, in __start__
File "xml\sax\expatreader.pyc", line 107, in parse
File "xml\sax\xmlreader.pyc", line 119, in parse
File "xml\sax\expatreader.pyc", line 111, in prepareParser
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe4' in position 44: ordinal not in range(128)
