I posted this over on Meedio's forum also with no replies yet and thought I would try here.
I am posting here because I don't what is the root cause of my problem, Meedios, Playmee, Movinight, Eventghost?
Right now these two are not having a happy relationship on my system. After searching and playing around with them for two days I must beg for help.
I am opening IFO files with Zoomplayer using Playmee and Movienight via Eventghost. Everything works wonderful unless the "stop" or "stoptofirst" commands are sent.
It works fine when out of Meedios but from within instead of a full Zoomplayer splash screen after stoping, Meedios openes back up and Zoomplayer appears to minimize to say a 20x80 box in the lower left hand corner. If I bust out my mouse and click on it the video comes back for about 2 seconds then Zoomplayer closes or minimizes and locks up. Meedios appears unafected.
I am hoping someone else has seen this and has some ideas.
Issues with Eventghost - Meedio - Zoomplayer
Re: Issues with Eventghost - Meedio - Zoomplayer
I am confused by your explanation of the proplem. I can tell you though that I use Meedio w/ Playmee to launch Zoom Player and I have no issues what so ever. Try to explain your issue again and I'll try to help you out. Make sure you look thru all of Zoom Player's options (there are many, take your time looking thru them) to see if it is a settings that is causing your problems.
