holding pressing a key
zinodemidoff
Hello, could somebody help me. what action can i use for emulation holding pressing a button. eg i hold alt and press tab
Re: holding pressing a key
You can use the keystroke emulation. Go to add macro, then window (I believe) and there you will find emulate keystroke. In the options for this macro, you can configure things like this.
