Technisat TTS35AI / USB IR-Receiver -> I need your help
Friesen1987
Post by Friesen1987 »
Hello Together.
-- Sorry for my bad English !! --
I would like first to thank the developers and the Forum! :D
Nevertheless, I have a problem with my remote -> Technisat TTS35AI / USB IR-Receiver
What I've found out:
1 - The USB dongel (0900/3704) HID as we recognized in the Windows (HID \ VID_147A & PID_E02D & COL02 \ 6 & F39EEA4 & 0 & 0001)
2 - Some buttons are function with keyboard as editor:
Power = no function (as editor)
1 = 1
2 = 2
3 = 3
4 = 4
5 = 5
6 = 6
7 = 7
8 = 8
9 = 9
0 = 0
Mute = m
-/-- = R
A/B = s
red = HH:MM DD.MM.YYYY (time + date)
green = no function (as editor)
yellow = no function (as editor)
blue = no function (as editor)
Top = top
Down = down
Left = left
Right = right
SFI (EPG) = e
Exit (update) = f
i (Info) = i
Program + = top
Program - = down
Volume + = right
Volume - = left
TV (Radio) = no function (as editor)
Menu = no function (as editor)
Help = i
TXT = t
Stop = p
EXT = v
User Key 1 = no function (as editor)
User Key 2 = no function (as editor)
User Key 3 = no function (as editor)
User Key 4 = no function (as editor)
3 - With the General HID plug-in RAW mode is "EG" me at the "Power button" "HID.020500" back
-> All other buttons are apparently with "EG" is not recognized
4 - VDR-link from the portal (Linux) with solutions for VDR (may also be helpful here)
-> http://www.vdr-portal.de/board/thread.p ... adid=64604
5 - Have a file "remote.tgz" (annexed) found with the remote command (may also be helpful here)
Can one help me with my problem in which the "General HID-plug" reprogrammed?
Thank you ever for your help :D
Greeting
Friesen
PS: I have the following versions tested
1 - EventGhost_0.3.5c
2 - EventGhost_0.3.6.1431
remote.tgz
(1.85 KiB) Downloaded 315 times
theviper06
Re: Technisat TTS35AI / USB IR-Receiver -> I need your help
Post by theviper06 »
a possible and working solution can be found here:
http://www.autohotkey.com/forum/topic10416.html
like someone wrote is it necessary to modify the .inf for USB.
Download the latest beta version (0.3.7.r1262).
There is a plugin for TechniSat receiver.
sabron01
Post by sabron01 »
hi freinds i try the last beta version of eg but the new plugin for technisat IR usb receiver dont work.
when i try to make it work ----->eg send a error msg and said that my device is not found
so is there anyone who can help me plz.
There was the driver installation after the addition of plug-in EG?
If so, and yet it does not work, you can have a different version of hardware (eg different VID and PID)
You can try the following:
1. Download USB driver from here
2. Open USB-Remote-Driver.exe with 7Zip or WinRar and extract content somewhere.
3. Edit driver.inf - for example change VID and PID in section TechniSat USB IR Receiver
4. Run DPInstSwitcher.exe from the directory you extracted USB-Remote-Driver.exe to. This should install the alternative USB driver.
Another advice I can not give. I have not owned Technisat USB IR Receiver.
sabron01
Post by sabron01 »
hi Pako
i found this error msg in eg
Error starting plugin: TechniSat USB IR Receiver
Device not found!
in fact the technisat USB IR RECEIVER was found in my hardware list but it seem that there is some problems with it.
sabron01
Post by sabron01 »
sabron01 wrote:hi Pako
Device not found!
no help !!!!!!!!!!!!!!
i still wait ur help my freinds
topix
Post by topix »
Did you already try the 0.4.0-version of EG? look here
sabron01
Post by sabron01 »
thanks freinds
i try it but nothing work.
i think that my ir usb receiver dont work ;there is a material problem.
is there another type of remote that work with my skystar2 crad dvb.
thanks .
technisat10
Post by technisat10 »
I have TS35 remote and default HID buttons is:
Mute m
EXT v
A/B (Swap) s
POWER not working
0-9 0-9
TV/RADIO F9
-/-- r
INFO/Hilfe i (2 buttons the same)
MENU F2
Up Up
Down Down
Left Left
Right Right
OK Enter
SFI (EPG) e
Exit f
Red F5
Green F6
Yellow F7
Blue F8
v not working
TXT t
STOP p
I test Girder 3.2.9b + IgorPlug 1.0.1.0 + COM IR receiver from SkyStar2, settings: Input Signal DSR, Priority level: 8
All the buttons are working properly and have different codes:
-/-- - 328A
v - 22B6
POWER - 328C
Interestingly, the INFO button has a different code than HILFE button:
INFO - 228F
HILFE - 328F
With default WinXP HID driver Technisat USB IR receiver working properly this buttons:
-/-- - letter r
and INFO=HILFE - letter i
but not working this buttons: POWER, v
What's going on? It follows that the remote is working properly. This is bad drivers HID & EvenGhost or bad Technisat USB IR receiver.
