Block Keyboard Events
specter333
Post by specter333 »
If I remember correctly, I used to be able to block some keyboard events by assigning them to macros that didn't do anything. For example I want the keyboard volume up and volume down keys to not be able to control the system volume.
I just installed the latest EG version and now I can't block those events. Of course I don't really remember if I was blocking those keys before the update.
Is it possible to keep those keystroke from going to the system?
topix
Re: Block Keyboard Events
Post by topix »
I just tried it with EG 3.6.1431 and it works. The keys get blocked.
Do you have the keyboard-plugin added?
specter333
Just got back to this and it's working now. Maybe I just needed to restart a few time to get it to work??? Thanks anyway.
