use remote button squence to trigger event?
johnmacd
Post by johnmacd »
I already have my "mute" button on my remote set to mute. I'd now like to be able to set it so that if I press the "mute" button 3 times very quickly, it will execute a batch program.
Basically what I am trying to do is reboot the machine if the mute button is pressed 3 times very quickly. I already have a small batch program that will shutdown my open programs and then reboot the machine. I want to be able to trigger this program with pressing the mute button 3 times, but I already have the mute button set to another command (mute).
Is this possible to set up?
specter333
Re: use remote button squence to trigger event?
Post by specter333 »
It's probably possible but tricky since your already using the mute key.
Off the top of my head, I'd let it go ahead and mute the system on the first press but also enable a macro.
That macro would disable itself if another mute command is not received in say 1 second.
If the second mute is received then it enables a third macro that would also disable itself if the mute command isn't received and if it is it would execute the reboot program.
I'll try to make that a little clearer.
First macro,
Receives mute
Mutes system
Enables second macro
Pauses or ignore events to keep a loop from starting
Second macro,
Receives second mute
Enables third macro
Disables itself
Third macro,
Receives third mute command
Starts reboot program
Disables itself
That's what I would do, maybe some of the more experienced guys can come up with a better way.
You could also try the jump if long press action. Maybe you could use a long mute press instead of three presses.
Good Luck
Rich
bskchaos
Post by bskchaos »
What about long button press?
pr0n!!!
jsonnabend
Post by jsonnabend »
I have something similar in my setup. Maybe it will help.
I have a key that enters "macro" mode (it's the star key, but could be any key). In that mode, the system waits for up to three numeric key inputs, or one or two keys plus an "enter" key, or one or two keys plus a time out. It then fires an event based on the input number.
The way it works is that hitting the star key enables exclusively a node that processes the remote inputs (keeping them away from normal system control). At start of "macro" mode, a timer is set. If a key isn't received in that time, the node is disabled and the usual node re-enabled, ending "macro" mode.
If a key is received before the time out, the timer is reset, waiting for another key. When all three keys are received, or one or two plus "enter", or one or two plus a time out, the number-based event is fired.
This setup could easily be adapted for multiple key presses of the same key, I think.
I didn't set this up as a plugin, so I'm not sure how best to share my setup. If anyone has any ideas, I'm all ears.
- Jeff
