let say that i want to make an event by pressing an remote(tellstick duo), but i need to press the remote repeatedly for example 3 times in a row before that event occurs.
is there a plugin that works like that?
repeating to make an event plugin?
- kgschlosser
Re: repeating to make an event plugin?
sure is. it's called multitap. that will allow you to marry the events from the remote. and if it sees that even a specified number of times within a specified amount of time it will trigger an event
thank you for quick reply,kgschlosser wrote:sure is. it's called multitap. that will allow you to marry the events from the remote. and if it sees that even a specified number of times within a specified amount of time it will trigger an event
i have looked at the plugin, but im not sure if it works like i wan, i will try to explain more precise.
what im looking for is a plugin that will trigger an event if another event has been triggered for example 3 times in a row, if not the repeated events occur in that specific timespan nothing will happen, but if triggered inside that time span, a new event will be triggered.
hope you understand.
Have you tried the jump if duplicate event?
It won't give you the three repeats you want but with some creative use it might get you what you need.
ok i will look at it, thanks.DanRoss wrote:Have you tried the jump if duplicate event?
It worked, thanks
