So, I have finally updated my trusty Streamzap remote for a new fangled Harmony thingy. I am still using my Streamzap IR Receiver.
EventGhost has been working flawlessly for me in controlling MediaPortal, EventGhost is so good - it just works.
I have been able to work out how to make my new Harmony be recognised by EventGhost as a Streamzap, and this works perfectly. What I would like to do is to be able to use some of the additional keys on my Harmony (such as Guide, info) which Streamzap just does not have.
I feel able to program the necessary within EventGhost, but it seems my Streamzap receiver just does not recognise the key presses. I have heard there is a Girder plug in for Streamzap which might allow me to achieve my aim, but I am so happy with EventGhost, I am reluctant to switch back. There have been enough similar queries on various sites to indicate I am not the only one trying to do this or something similar.
Any suggestions??
Streamzap remote
- Bitmonster
Re: Streamzap remote
The Streamzap receiver theoretically can receive other codes, but its sample time is quite high and therefore many IR protocols wont work. I would try to find some devices that use the RC5 protocol. All older Philips devices should use this protocol, so I would try to find a Philips VHS-VCR code in the database.
