What I am looking to do is set up the OK and Cancel buttons for the action Show Message Box. Is there a way to set up the OK button to do something.
Here is what I am trying to do:
What I would like to is when I hit the ok button I want to open a folder.
I'd really like to learn how to configure the other buttons as well but the ok and cancel button explinations would be awesome.
Eventghost Version: 0.4.1.r.1722
Windows 10
How to configure the Show Message Box buttons
internaltheory79
- kgschlosser
Re: How to configure the Show Message Box buttons
you need to be opening the message box from a script or a plugin
so what you would do is this.
this is all pseudo code and I have not tested it but it looks right. could have a typo somewhere tho
# different styles available
# wx.ICON_EXCLAMATION
# wx.ICON_HAND
# wx.ICON_ERROR
# wx.ICON_QUESTION
# wx.ICON_INFORMATION
# these can be added to the styles above with a | as a seperator
# wx.YES_NO
# wx.OK
# this style can be added if the wx.YES_NO is used
# wx.NO_DEFAULT
# these styles can be added to any combination of the above
# wx.STAY_ON_TOP
# wx.CANCEL
dlg = eg.MessageDialog(
parent=eg.document.frame,
message='This is a Test Message',
caption='This shows in the dialog title bar',
style=wx.YES_NO | wx.ICON_QUESTION,
pos=(100, 200) # this is for where you want the dialog to show up on the screen
if dlg.ShowModal() == wx.ID_YES:
CODE YOU WANT TO RUN IF THE YES BUTTON IS PRESSED
CODE YOU WANT TO RUN IF THE NO BUTTON IS PRESSED
dlg.Destroy()
@ kgschlosser: I think he refers to
Hello internaltheory79,
if you press one of the buttons, EventGhost generates an event automatically, you should see it in the log if you press a button.
You can use this event to execute whatever action you want (e.g. open a folder)
eg.plugins.EventGhost.ShowMessageBox()if you press one of the buttons, EventGhost generates an event automatically, you should see it in the log if you press a button.
- kgschlosser
OK I have never used that before
thanks Semi
thanks Semi
