Passing variables from Pushbullet to Eventghost
jokkkkker
Post by jokkkkker »
I recently got pushbullet on all my devices and pushbullet plugin on tasker and Eventghost as well. I was able to set up how to pass a static message/notification to Eventghost which then triggers a task.
What I am wondering if there is a way to pass on a variable message/notification from tasker to Eventghost that can be displayed on screen using OSD.
Re: Passing variables from Pushbullet to Eventghost
Of course. It is very easy.
Tasker has Pushbullet plugin. When you create a task, you can set the Title and the Message.
It is obvious that you can use Tasker-variable, so message field will contain (for example) the term "%MyVariable" (without the quotation marks).
Suppose the title is "MyTitle" (hard) and the variable "%MyVariable" has a value of "MyMessage".
If the appropriate Tasker profile (which includes task with Pushbullet message) is activated, in the Eventghost log a new event appears.
It looks like this:
PushBullet.Note.MyTitle [u'MyMessage', None, u'xXxXxXxXxXxXxXxXxXxXxX', u'MyPhone', '2016-10-23 13:52:04']
You can create a new macro, to which you associate the event "PushBullet.Note.MyTitle".
This macro might look like this:
That's all - it's really very simple.
jokkkkker
Post by jokkkkker »
Works like a charm!! Thanks!
