Get result from "windows command"?
I can't for the life of me figure out how to get what a "windows command" returns back into eventghost. I'm running 'nssm status <service_name>' and I expect something like 'SERVICE_RUNNING' as a result, but all I'm getting in eg.result is 'S'.
Re: Get result from "windows command"?
Perhaps it has something to do with nssm. If I execute a standard windows command like 'dir' or 'ipconfig', I get the entire response in eg.result.
- kgschlosser
run the command in command line window and read the screen....
that's what it will return
C:\WINDOWS\system32>nssm status deluged
SERVICE_RUNNING
C:\WINDOWS\system32>Code: Select all
nssm status delugedCode: Select all
S[edit] Same result if I run as administrator.
Perhaps it has something to do with your showOCD configuration. What is the actual value of eg.result? Right after your windows command, add the python command "print eg.result". What is shown in the log pane?
- kgschlosser
make sure you have the "wait until application has terminated before proceeding" checked
if you don't it won't hang around and wait for the output
Ok the problem is nssm, specifically the release version "nssm 2.24 (2014-08-31)". Pre-release "nssm 2.24-87-g203bfae (2016-08-26)" works.
Crossing my fingers the pre-release is stable, and hey maybe there's other bug fixes.
- kgschlosser
ok so you have the problem narrowed down to the version of nssm you are using. cool beans.
