Any way to send events from EG to SmartThings?
therealbiglou
Post by therealbiglou »
I've got this smart app working to send events from SmartThings to Eventghost: https://community.smartthings.com/t/sen ... host/22473
What I would like to do, however, is also send events from EventGhost to SmartThings. The reason is that sometimes things get out of sync. I can use SmartThings to turn on/off my TV, but if I use another method to turn it on/off, it doesn't update the state in SmartThings. Because of this, the controls don't always work.
Is there a way to update SmartThings based on actions in EventGhost?
yokel22
Re: Any way to send events from EG to SmartThings?
Post by yokel22 »
Maybe i'm misunderstanding what your wanting. But can't you use the REST api here? http://docs.smartthings.com/en/latest/s ... part2.html. I've not used smartthings but that seems pretty odd that it wouldn't update the status of a device when it detects a device change. Or is it that it's just not being forwarded through the smartApp?
therealbiglou
The smart app is one way only. It only sends things to EventGhost, but it doesn't receive anything back.
yokel22
Post by yokel22 »
Yes, but you could use the API i linked to to send info to the smartthings hub. It would be a bit more complex than most REST api's as they are using a token based system & you would need to install the Oauth2 module as a dependancy. I can try & explain further, if you decide it's worth your time to persue it.
Even simpler, use MQTT.
See the link below how to setup and link a MQTT broker to SmartThings. Then use the MQTT Client in EG to get a possible 2-way communication EG <-> SmartThings
https://home-assistant.io/blog/2016/02/ ... Assistant/
