[FIXED] FHZ 1300
garbageman
[FIXED] FHZ 1300
Post by garbageman »
Hello everyone!
Obviously the german part of the forum is not the most frequented place, so please forgive me for placing the same problem in two forums...
I want to control my FHZ 1300 using this great problem. But all I see in Eventghost (latest version 3.6.1430) is this error message when I try to test a command:
File "C:\Programme\EventGhost\eg\Classes\ConfigPanel.py", line 126, in OnTestButton
self.gr.switch(eg.ID_TEST)
File "C:\Programme\EventGhost\eg\Classes\UndoHandler\Configure.py", line 54, in Do
newArgs = gr.switch(*item.GetArgs())
File "C:\Programme\EventGhost\plugins\Fhz1000Pc\__init__.py", line 273, in Configure
address = self.GetAddressFromString(maskedCtrl.GetPlainValue())
File "C:\Programme\EventGhost\plugins\Fhz1000Pc\__init__.py", line 250, in GetAddressFromString
address += (int(addressString, 4) - 1)
ValueError: invalid literal for int() with base 4: '4'
Can someone advice what to do?
Thanks in advance!
jinxdone
Re: FHZ 1300
Post by jinxdone »
Hello.
It seems there is an error in the plugin script, it's trying to store a value '4' in a base 4 integer which can only hold values from 0 to 3.
So in other words if you enter a '4' anywhere in the address field it will break. I'm not familiar with these devices so I can't really fix it since I have no clear idea what it's supposed to be doing in the first place.. :?
garbageman
Re: FHZ 1300
Okay...so wouldn't it be the solution to extend the int definition to 5? Addresses in this FHZ system are always numbers with digits from 1 to 4, so it has to be possible to enter the value '4'.
Re: FHZ 1300
I assume you quickly could try to change yourself and try and then report back if it worked. I think this is the place in the plugin (if this is the actual problem of course)
BestR Walter
    def GetAddressFromString(self, addressString):
        address = 0
        for i in range(12):
            address <<= 2
            address += (int(addressString[i], 4) - 1)
        return address
Re: FHZ 1300
Post by Bitmonster »
Yes, this is a bug. I have never tested codes with "4" in them. Will be fixed in the next beta. But might take some days.
Topic moved to "bug reports".
Re: [OPEN] FHZ 1300
The latest beta should work now.
