New Plugin: Technotrend C-1501 Remote
mastalee
Post by mastalee »
Hi
I have written a plugin to use the onboard reciever of the newer technotrend Budget PCI cards.
I have trested the plugin with a C-1501 DVB-C card and an two rc5 remotes. But according to the technotrend driver api it should work with any technotrend budget cards, even usb.
t oacces the DVB card you need a driver-api-dll from the technotrend BDA-Driver-SDK called "ttBdaDrvApi_Dll.dll" i'm not shure if i'm allowed to upload this file here.
You can get this file from an dvbviewer installation or from the dvnviewer-forum
the plugin have no configuration and uses the first budget
Technotrend Budget Remote Plugin
(4.73 KiB) Downloaded 442 times
Re: New Plugin: Technotrend C-1501 Remote
Post by Bitmonster »
I just took a quick look at the code.
mastalee wrote:and uses the first budget
What does "budget" mean in this context? The first card (if more than one are installed)?
mastalee
Post by mastalee »
yes,
the first technotrend dvc-c budget card ist used if multible cards are installed in the system.
SanSiro
Post by SanSiro »
i would like to use this plugin but i can't add it to my configuration (doesn't show up in the list of available plugins). I copied the plugins .py file and the dll to a separate folder under plugins (tt1501). When i startup eventghost it show to messages in the log windows to the right with the message "Technotrend C-1501".
I'm using the newest beta 0.3.6.1487.
Thanks for your help
SanSiro
shady
Post by shady »
I encounterded the same problem today. To make the plugin work with the actual release of EventGhost I had to modify the registration routine.
I hope this is OK with mastalee. Thank you for your excellent work!
To install the plugin perform following steps:
- Create a new subfolder of your choice in the plugins directory
- Place the attached .py file in that folder
- Unzip the ttBdaDrvApi_Dll.dll from the link in the first post and place it in the same subfolder
Once EventGhost is started the new plugin can be selected from the plugins menu.
(4.71 KiB) Downloaded 342 times
morph
Post by morph »
ich habe zwar eine usb tt-3600 aber die DLL ist zumindest laut name der gleiche. (ttBdaDrvApi_Dll.dll (200.704 Bytes))
das ganze ist ohne Hub direkt an den Rechner angeschlossen. Beim start gibt GE dies aus:
TTIR:__start__
pluginDir=C:\Programme\EventGhost\plugins\TT
dll= <CDLL 'C:\Programme\EventGhost\plugins\TT\ttBdaDrvApi_Dll.dll', handle 46c0000 at 20e5550>
die letzte Zahl ändert sich bei jedem Start, aber wenn ich eine Taste auf der Fernbedienung drücke, erscheint nichts im log fenster.
mastalee
Post by mastalee »
i added support for usb dvb devices to this plugin.
BUT: i dont have a usb dvb device so this code is untested!
(5.21 KiB) Downloaded 344 times
mastalee
Post by mastalee »
so this version should work ;)
what is missing: Standby and Resume support
(5.04 KiB) Downloaded 458 times
morph
Post by morph »
funktioniert einwandfrei, vielen dank für die große mühe, die du dir mit dem plugin gegeben hast und es immer wieder überarbeitet hast.
Works perfect with winamp.
goelli
Post by goelli »
thanks very much for this plugin! It obviously works with TechnoTrend TT-Connect S2-3650 CI USB-Receiver. Just tested it.
Greetings
