Using OSD and display current volume level [SOLVED]
bskchaos
Re: Using OSD and display current volume level [SOLVED]
Post by bskchaos »
Try this:
<EventGhost Version="1540">
    <Folder Name="Volume Control" Expanded="True">
        <Macro Name="Decrease Volume" Expanded="True">
            <Event Name="X10.VolumeDown" />
            <Event Name="ErgoMouse.Button.234" />
            <Event Name="HID.Button.3" />
                System.ChangeMasterVolumeBy(-5.0, 0)
            <Action id="762">
                EventGhost.ShowOSD(u'{"c" *int(round(eg.result) * 0.20) + "g" *int(round(100-(eg.result)) * 0.20)}', u'0;-12;0;0;0;400;0;0;0;2;3;2;1;18;Webdings', (255, 255, 255), (0, 0, 0), 3, (8, 48), 0, 2.0, True)
                EventGhost.AutoRepeat(0.40000000000000002, 0.050000000000000003, 0.01, 0.40000000000000002)
        <Macro Name="Increase Volume" Expanded="True">
            <Event Name="X10.VolumeUp" />
            <Event Name="ErgoMouse.Button.233" />
            <Event Name="HID.Button.4" />
                System.ChangeMasterVolumeBy(5.0, 0)
            <Action id="770">
        <Macro Name="Mute Sound Card" Expanded="True">
            <Event Name="X10.Mute" />
                System.ToggleMute(0)
                EventGhost.NewJumpIf(XmlIdLink(777), 0, False)
                EventGhost.ShowOSD(u'X\xf0', u'0;-64;0;0;0;400;0;0;0;2;3;2;1;18;Webdings', (255, 255, 255), (0, 0, 0), 3, (16, 56), 0, 2.0, True)
        <Macro Name="Show OSD: Mute ON" id="777" Expanded="True">
                EventGhost.ShowOSD(u'Xr', u'0;-64;0;0;0;400;0;0;0;2;3;2;1;18;Webdings', (255, 255, 255), (0, 0, 0), 3, (16, 56), 0, 0.0, True)
InterlinkKnight
Post by InterlinkKnight »
That works, thanks. But I don't understand why works like this. I mean, how you setup this manually (without editing the XML file)?
bskchaos
Post by bskchaos »
copy the code an paste into EG
InterlinkKnight
bskchaos wrote:copy the code an paste into EG
Every time i try that doesnt work. Shows: "X├░" and that's it
bskchaos
Post by bskchaos »
Remember that you must use the font Webdings
InterlinkKnight
bskchaos wrote:Remember that you must use the font Webdings
You are right. Dah!. My mistake. Although you forgot to mention that you need to add a macro and a JUMP action to show when sound is muted. I am not sure how to do that, but i think i can figure it out.
Overall, this technique work and I will include it on the main instructions as another way to do it, but is complicated to do it right. For example I notes that if i change the increase volume rate from 5% to any other (like 4%), the bar move strange. It need a specific setup to work good. Even so, is useful.
Thanks for the help.
bskchaos
Post by bskchaos »
I know that it lacks precision. But I prefer it instead of a long bar.
The logic behind the Mute OSD is this:
"Toggle mute" disables sound and the "If susessful..." jumps to another macro with the Mute On OSD.
If you press mute again the "If susessful..." criteria won't be meet and the next action (Mute Off OSD) is executed.
tomde
Post by tomde »
Sound {("On", "Off")[eg.result]}
works fine
Volume - {eg.WinApi.SoundMixer.GetMasterVolume()}
shows always 100% - (but Volume is changing)
Volume - {int(round(eg.result))}%
force an error:
Log: Decrease Volume
Verändere Master-Lautstärke: -3.00 %
Automatische Wiederholung: 0.6
Zeige OSD: Volume - {int(round(eg.result))}%
Fehler in Befehl: "Zeige OSD: Volume - {int(round(eg.result))}%"
Traceback (most recent call last) (1540):
File "C:\APPS\EventGhost\eg\Classes\ActionBase.py", line 170, in CallWrapper
return self(*args)
File "C:\APPS\EventGhost\plugins\EventGhost\ShowOSD.py", line 385, in __call__
osdText = eg.ParseString(osdText)
File "C:\APPS\EventGhost\eg\Utils.py", line 204, in ParseString
res = eval(word, {}, eg.globals.__dict__)
File "<string>", line 1, in <module>
TypeError: a float is required
Any idea? Thanks, Tom
InterlinkKnight
tomde wrote:Hello,
Don't use that code because doesn't work on Windows 7, unless you run Eventghost in Windows XP sp3 compatibility mode. You better use the other code (I show the solution next).
force an error:
return self(*args)
The error is caused because you place the "Autorepeat current macro" before the OSD command. As I say in the instructions, you need to place the "Autorepeat current macro" after the "Show OSD".
Should work after you fix that.
tomde
Post by tomde »
Now, it works perfect. Thank you.
debennett2
Post by debennett2 »
FF.VolumeUp
   Change Master Volume: 0.50 %
      Show OSD: Volume - {int(round(eg.result))}%
         Error in Action: "Show OSD: Volume - {int(round(eg.result))}%"
         Traceback (most recent call last) (1544):
           File "C:\Program Files\EventGhost\eg\Classes\ActionBase.py", line 170, in CallWrapper
             return self(*args)
           File "C:\Program Files\EventGhost\plugins\EventGhost\ShowOSD.py", line 385, in __call__
           File "C:\Program Files\EventGhost\eg\Utils.py", line 204, in ParseString
      Autorepeat current macro: 0.6
Any ideas? This is in a Windows 7 machine. I'm lost.
debennett2 wrote: I'm lost.
I'm also lost.
I need to see not only the result but also a source or originator of it.
Why are you here did not give either a screenshot or your configuration file?
Thus, it seems that there are missing the action Change Master Volume.
It must be before the action Show OSD.
InterlinkKnight
Pako wrote:Why are you here did not give either a screenshot or your configuration file?
I was thinking that you can do it yourself, with your own "change master volume". I mean, this is to show the volume, not to make a volume change button. Anyway, you are right. I better place the configuration file in here just in case anyone is lost:
<EventGhost Version="1544" Guid="{93CA3DF2-7148-4B9C-9F06-FB3D578935B9}" Time="1327405609.27">
    <Autostart Name="Autostart" Expanded="True">
        <Plugin Identifier="Lirc" Guid="{17A77662-BB69-4C37-AA43-71213958C5C4}" File="Lirc">
            gAIoWAkAAAAxMjcuMC4wLjFxAE09IomJiUsAS8iIS0BLCnRxAS4=
        </Plugin>
    </Autostart>
    <Folder Name="Change Volume">
        <Macro Name="Volume Up">
            <Event Name="Lirc.vol+" />
                System.ChangeMasterVolumeBy(1.0, 0)
                EventGhost.ShowOSD(u'Volumen {int(round(eg.result))}%', u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', (255, 255, 255), (0, 0, 0), 5, (0, 100), 0, 3.0, True)
                EventGhost.AutoRepeat(0.5, 0.20000000000000001, 0.029999999999999999, 0.0)
        <Macro Name="Volume Down">
            <Event Name="Lirc.vol-" />
                System.ChangeMasterVolumeBy(-1.0, 0)
        <Macro Name="Mute" Expanded="True">
            <Event Name="Lirc.mute" />
                System.ToggleMute()
                EventGhost.ShowOSD(u'Mute {("Off", "On")[eg.result]}', u'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial', (255, 255, 255), (0, 0, 0), 5, (0, 100), 0, 3.0, True)
That solve your problem?
configuration
configuration
ScreenShot - 2012-01-24 - 07.24.11 - 001.jpg (35 KiB) Viewed 10856 times
bskchaos
Post by bskchaos »
The new event (system.volume) seems to be accurate and I want to use it for a better volume bar.
Right now I need to convert the eg.event.payload to a number, need help with this.
BTW, this code should help those trying to use a Mute icon OSD.
<EventGhost Version="1568">
    <Folder Name="Volume" Expanded="True">
        <Macro Name="Mute Sound Card">
            <Event Name="HID.Button.225" />
        <Macro Name="Show OSD: Mute ON">
            <Event Name="System.UnMute" />
                EventGhost.ShowOSD(u'X\xf0', u'0;-96;0;0;0;400;0;0;0;2;3;2;1;18;Webdings', (255, 255, 255), (0, 0, 0), 3, (32, 32), 0, 2.0, True)
            <Event Name="System.Mute" />
                EventGhost.ShowOSD(u'Xr', u'0;-96;0;0;0;400;0;0;0;2;3;2;1;18;Webdings', (255, 255, 255), (0, 0, 0), 3, (32, 32), 0, 0.0, True)
Vilsepi
Post by Vilsepi »
First of all, thanks for everyone for this thread. I've been using EG for a couple of years but for some reason I've been neglecting the OSD completely. Today I started to come up with a simple volume OSD.
bskchaos wrote:The new event (system.volume) seems to be accurate and I want to use it for a better volume bar.
That's what I also wanted to use (didn't actually know any other alternative). My problem with System.Volume was that the payload is a string, depicting a float/double with a comma as a decimal separator. Having the comma instead of a period is what seems to fail the type conversion, thus I simply split the string from the comma and take only the numbers before it:
Value only:
Volume: {eg.event.payload.split(",")[0]}%
Volume bar (100 characters long, made of | and .)
Volume: {"|"*int(eg.event.payload.split(",")[0])+"."*(100-int(eg.event.payload.split(",")[0]))}%
Shorter volume bar (20 characters long, made of | and .) with numerical value in the end
Volume: {"|"*((int(eg.event.payload.split(",")[0]))/5)+"."*((20-int(eg.event.payload.split(",")[0])/5))}%
Webdings bar (20 characters long, made of blocks), make sure you set font to Webdings!
{"g"*((int(eg.event.payload.split(",")[0]))/5)+"c"*((20-int(eg.event.payload.split(",")[0])/5))}
Webdings bar (50 characters long, made of blocks), make sure you set font to Webdings!
{"g"*((int(eg.event.payload.split(",")[0]))/2)+"c"*((50-int(eg.event.payload.split(",")[0])/2))}
Hope this helps. It could be a bit too heavy, I dunno, but I think I might be going with just the numerical display.
Webdings bar
Webdings bar
Ascii volume bar with numerical value
Event payload has a float with a comma-separator
