config a button to auto-repeat while keep it pressed, how?
THX-UltraII
When I press eg. the right button of my remote in XBMC AND KEEP IT PRESSED, he only slides ONE place to the right. Is it possible to config eventghost in some way so it behaves the same as pressing your keyboard right button AND HOLD IT (so that the right click repeats over and over untill I let go of the button?).
Re: config a button to auto-repeat while keep it pressed, how?
In actions:
EventGhost -> Autorepeat current macro
THX-UltraII
thxz for your reply. That did the job!
Hey, I got the same question but I can't find the German equivalent to "Autorepeat current macro". Can you tell me some details please? Thanks in advance.
You can find it here:
Perfect, thanks a lot!
Hi, I have added the "auto-repeat" option to my macro, but it's not working.
I am using the USB-UIRT device for input. When a I press and hold the button down, I can see the red light on the USB-UIRT continue to flash, so I know it is getting the commands. When I first press a button it is logged and executed in EventGhost, but I just never get the repeated event. I have tried this with several remotes.
I've double-checked to make sure the Autorepeat action was assigned to these macros, and they are.
Any suggestions?
EventGhost Version:
0.3.5c build 908
SVN Revision:
112
Compile Time:
Mon, 16 Apr 2007 17:32:45
Python Version:
2.5.0 final 0
wxPython Version:
2.8.1.1
PIL Version:
1.1.6
Platform:
Windows-XP-5.1.2600-SP3
Any suggestions?
EventGhost Version:
0.3.5c build 908
SVN Revision:
112
Compile Time:
Python Version:
2.5.0 final 0
wxPython Version:
2.8.1.1
PIL Version:
1.1.6
Platform:
READ THIS before posting anything!
0.3.5c build 908 is a very old version, which has long supported not. Try the latest beta version!
Thanks Pako. I'll check that out.
FWIW, I downloaded EventGhost today through the link in the Wiki (to sourceforge) so I assumed I had the latest version.
Also, the link that the page gives to the different builds many versions. The version notes for the last one says "many new bug". Not for me.
Do you recommend a version that is stable and that perhaps my Auto-repeat bug will be fixed?
I am using version 0.3.7 and for me works better, than previous versions. But I am not using a USB-UIRT.hal wrote:Do you recommend a version that is stable and that perhaps my Auto-repeat bug will be fixed?
When you not to use the latest version, you can use, for example, version 0.3.6.1487.
Try Autorepeat configuration according to the attached image.
- Autorepeat.png (8.57 KiB) Viewed 9168 times
i'm using the igorplug...
and the latest beta (0.3.7.r851)
wenn i press a button on my remote
the event get startet for example next channel ...
the i put the auto repeat macro in the event... but nothing happens wenn i press the button longer...
only in the log there is a
i [8956, 2217, 597,21751]
this repeats as long i press the button...
any idea?
any idea?
