vista compatibility
boykillsworld
vista compatibility
Just curios where you guys are in terms of windows vista compatibility. I realize that most of this stuff doesn't even have drivers for vista yet but do you think the port will be quick or slow and painful.
boykillsworld
- Bitmonster
boykillsworld
- Bitmonster
no go for build 939
Just FYI: I tried running build 939 in Vista with no luck. I can successfully run it from the command line using the -n switch to send instructions to another machine, but I can't get a GUI. Watching the task monitor, I see EG start, then quit.
LanceDrolet
- Bitmonster
Well, 939 has many code changes. Since I have no Vista machine, I have no clue were it might crash. You could try to start EG with the "-debug" parameter and look into the log. Maybe there is some information that might help.
