key hold ????
guinness
key hold ????
Post by guinness »
hello,im currently shut-down my pc using the 0 on my remote control,but i would like to give a delay like normal tv remote,i mean i want to hold the 0 for about 3 second to make it shut-down.
can it be possible?
thanx
Re: key hold ????
guinness wrote:hello,im currently shut-down my pc using the 0 on my remote control,but i would like to give a delay like normal tv remote,i mean i want to hold the 0 for about 3 second to make it shut-down.
can it be possible?
thanx
There is a action Jump if long press that should work if the plugin you use for your remote supports it.
guinness
Re: key hold ????
Post by guinness »
look like is not working with the xbmc plugin.
Re: key hold ????
guinness wrote:look like is not working with the xbmc plugin.
How did you try? The XBMC plugin should work fine with it.
What plugin do you use for your remote? The Hauppauge IR plugin I use has a problem to properly detect when a button is held down, so I can't use the Jump if long press action.
If your remote supports programming you could make it send a different keycode when a button is held down.
guinness
Re: key hold ????
Post by guinness »
im using the the original xbox1 remote with XBCDRC plugin,would that be the problem?
Re: key hold ????
guinness wrote:im using the the original xbox1 remote with XBCDRC plugin,would that be the problem?
I don't know, I think there is a simple test to see if the remote plugin supports holding a button.
If you press a button on the remote you will see it in EventGhost's log window, now if you hold a button do you see it repeating or only once?
If you only see it once while holding a button I'm guessing it should work with the Jump if long press action.
I assume this is the right way to use the Jump if long press action, HauppaugeIR.35 is the button I tested, it didn't work for me as the button just repeats.
Did you try something like this?
guinness
Re: key hold ????
Post by guinness »
i tried and is not repeating, is only once.
still cant make it work.
jinxdone
Re: key hold ????
Post by jinxdone »
I think the easiest action to test with is the "Start mouse movement in direction" action. It should move the mouse cursor while you press and hold the button you assign to it.
Anyway, it sounds like you might be having a problem with the remote plugin. Are you using an original xbox remote? (not third party). Do you sometimes get in your log "Unknown code received:" messages from the plugin?
Re: key hold ????
guinness wrote:i tried and is not repeating, is only once.
That's good, that should mean your remote plugin supports holding a button.
Like I asked before how did you try? attach your EventGhost config that didn't work.
