Set Display Preset Don't Go!! Help!
Hi guys i'm the same of the other post
EG 0.3.7.r1387 on Windows 7 64 bit... I'm tryng to use the "set Display Preset" action but it don't go.... I've grabbed the display configuration i need, than when I click on test or I use the action, my monitor flash but configuration it's still the same... Some ideas? I have an Ati Sapphire X1600.. Some trouble with the ati driver? Thank you! Bye bye
Re: Set Display Preset Don't Go!! Help!
mmm no one can help me?
mmmm no good...
adrenarush
I am having a similar issue trying to switch between a projector screen and the LCD monitor when I put the machines into a "theater mode" (dims lights, starts projector, starts media center, moves the display to the projector screen)
I am using an ATI Radeon HD 4800 on Win7 64 Ultimate
mmm good... another guy with the same problem
But no answer here for about 4 or 5 days... I don't think someone can help us
This bug has been posted before, but no one had found time investigating it.
I just did some basic test on my machine and it works (win7 pro x64, radeon 4850)
edit:
I also get some troubles when it comes to disabling/enabling monitors.
edit:
mmm ok so it's a bug... so we need to wait?
