Hello, I'll explain the setup I have first. I am using the playstation 3 remote with the playstation 3 plugin, on XBMC. I mostly have everything all working, just need to tweak it a bit for conveniance.
I am wanting to make use of the colour buttons for; exiting XBMC and for shutting down the pc. This is easy of course, but instead of just using a normal button press I want to hold down the button for a set amount of time. This way I would not be shutting down the pc by accident (life if I have a move on in the dark etc)
I have tried a couple of things out, trying some actions; but I can't get it to work.
What could be a majour problem is the fact that there are 2 HID functions on each button, one for pressing in and one for release. Since someone else made the original configuration, I have no idea if it was them that set it that way, or wheather it is the plugin or not.
I have also tried setting 2 buttons to be pressed in at the same time for closing, but I didn't get anywhere with that either.
Can anyone help me? I can post or upload the config file if anyone needs to analyse it.
Thanks.
Holding in a button
Re: Holding in a button
Ok, been trying to get this to work ove the last couple of days. And guess what? in 10 mins after updating the ps3 plugin; the rest fell into place. All done.
If I hold in red, it jumps to another macro (5 seconds) and exits xbmc. Same with blue, but shutting down the PC.
Sorry for wasting your time people!
