I am using XBMC Dharma beta2 on win 7 and the latest EG
My question is about listening to music with visualization (milk drop)
when the visualization starts there seems to be no way to exit without stopping the music
does anybody know the command in the XBMC plug-in to exit visualization?
Thanks. any help would be Great
How to get XBMC to exit visualization when playing music
Setup:
HOME THEATER- Integra DTR, Samsung LN52B750,Extron 8x8, Speaker Craft, Audio Pro and Klipsch.
REMOTES- Pronto TSU 9600,TSU 9400, TSU 9300 and RFX 9600.
HOME AUTOMATION- HAI Omni Pro II, Omnitouch 5.7e's ,HAI Music Gateway,UPB Lighting and Omnistat
Re: How to get XBMC to exit visualization when playing music
If you're using my XBMCRepeat plugin, the XBMCRepeat\Buttons\Remote\Display will toggle between visualization and the GUI.harlest wrote:My question is about listening to music with visualization (milk drop)
If you're using the default/included XBMC plugin, XBMC\Fullscreen should do the same.
Thanks jonib that worked!
I am using the default XBMC plugin. Whats the XBMCRepeat plugin do? Should I be using that?jonib wrote:If you're using my XBMCRepeat plugin, the XBMCRepeat\Buttons\Remote\Display will toggle between visualization and the GUI.
Setup:
It's an enhanced alternative plugin to control XBMC, supports a lot more functionality.harlest wrote:Whats the XBMCRepeat plugin do?
If you are using a remote, it has special remote actions that work better than direct actions, like the arrow keys have different function depending on if you watch a movie or do something else. Based on the XBMC remote for the XBOX.
I might be bias, but YesShould I be using that?
Thanks jonib
That sounds like something I want to check out. I looked in addons in EG and I didn't see it.
How do I add that to EG? And does it setup similar? Just drag the Ir codes over to the command?
What about the auto repeat macro to scroll through movie list fast is that the same?
Sorry for all the Questions. I love my XBMC and Event Ghost setup and if I can get better control.
I'm all over it!
I'm all over it!
Setup:
There was a link on my first reply, but go here for more info XBMCRepeat.harlest wrote:That sounds like something I want to check out. I looked in addons in EG and I didn't see it.
You just download the __init__.py and xbmcclient.py from the link above, and put them in a directory XBMCRepeat in the (EventGhost install directory)\Plugins. Then you can (after restarting EventGhost) add the plugin to the EventGhost setup.How do I add that to EG?
Yes, but the actions are in folders as there are many more then the defaul XBMC plugin.And does it setup similar? Just drag the Ir codes over to the command?
Yes.What about the auto repeat macro to scroll through movie list fast is that the same?
Thanks for all your help jonib
I am a man on a mission! will return with feedback
Again Thanks
Again Thanks
Setup:
Thanks Again jonib you were right lots of options with XBMCRepeat
I got new EG files setup for my win xp and win 7 HTPC's so many command options it's going to take so time
I'll have to rebuild the pronto pages for my remotes. It makes XBMC so much faster
Definitely the way to go
Setup:
