If you search, you will find that I have had a lot of problems with my Snapstream Firefly + CM15a. After months of troubleshooting, I finally got it fixed by installing snapstream.exe drivers, then manually copying over drivers from "x10setupnovideo.exe" installed in a sandbox. It worked for years.
I have just upgraded to Windows 7 64-bit and the old method does not work anymore -_-
Here are the problems I am having:
no X10 events in EG after resuming from standby
I will try the Intelliremote test soon
Problems
1) Standby problem mentioned above
2) Firefly not throwing any events.
In device manager I have the X10 ACPI complaint under USB devices (NOT the HID compliant driver)
Anyone have any ideas? I'm so frustrated to have had a working remote under XP and now Window 7, it exhibits the same problems as before
