Im trying to set it up with my Foobar2000. Im aware theres a plugin available but it doesnt allow me to make advanced settings.
Im trying to manipulate my mouse-cursor by sending it to the right place and click on a button. However, when a mouse-button is pressed in some regions of Foobars screen, it will not execute the command on which the mouse-cursor is placed on. Although i can see the icon-button getting repressed, but nothing happens.
It also doesnt work with the status-bar. Normally, when rightclicked there should be a contextmenu show up. With Eventghost taking over my mousebuttons, nothing happens.
Stangely enough some icon-buttons in foobar d├│ work with Eventghost. But i dont understand why some work and some dont.. because theyre all the same, except for the command theres no difference in the icon, its the same kind/type (shown in the upper toolbar)
__________________
Another question, is it possible to record a mouse movement? That would be so much easier than inputting the pixel-coordinates.. it takes a lot of time to determine the right spot.. very tiring
Nevertheless, thank you for coding this great and free app !!
