Change an event based on the current date
kmanpilkers
Post by kmanpilkers »
Hi guys,
I'm new to EventGhost, just started messing with it yesterday. I work for an insurance brokers and we need to automate the database cleanup and accounting close of day that is performed every evening (currently I have to do this manually). So far, so boring. But the challenging part is I need to be able to change an event based on the current date.
During the close day, you are asked if you want to "change the date" (yes, we really have a system that can't automatically change the date itself!). This is the point where you just edit the date and move it on a day, so from the 4th July to the 5th etc. for the next day. I want to be able to automate this part too. Presumably I will have to capture the current date as a variable somehow and then increment it by 1. Anyone know if this is possible/easy to do with EventGhost?
Thanks in advance for any help. :D
Kev
Re: Change an event based on the current date
Welcome on board!
Yes, with EventGhost you certainly can solve your problem.
You unfortunately did not write what should be the date format.
One of the ways to get the date is here:
The event then looks like here:
You can use (in some macro) this date as eg.event.payload.
But get the date is just the easier part of the task.
I think the bigger tproblem is how to use this date in your application.
kmanpilkers
Sorry, first time back on this forum in a while and I hadn't subscribed to this thread. Many thanks for your response, I will try this out.
kmanpilkers
BTW, it turned out there was a very simple way of me changing the date, so I never needed to capture it in the end - I could simply open a calendar from the UI and key the right-arrow. This will just select the next day, simple!
