Keystroke emulation with MCE remote
pse
Post by pse »
I am trying to emulate keystrokes using MCE remote, but it is not responding. I am using Microsoft MCE Remote - Vista/Win7 plugin where the reciever is Microsoft eHome IR Tranciever. Am I missing something, please help.
Example_6.xml
(797 Bytes) Downloaded 82 times
pse
Re: Keystroke emulation with MCE remote
Post by pse »
I explain what I am doing clearly. I am trying to use EG with MCE remote. However, I am stuck even when I am not using MCE plugin. That is when I press the green play button for volume it works, but it is not working for the rest of the emulation such as {Ctrl+F}. Could there be more action or event need to be added? If I can get this working I will be using MCE remote eventually. Please take a look at the image file. Appreciate any help. Thanks.
kkl
Post by kkl »
Have you tried "Uninstall Service" then "Install Service" for the AlternateMceIrService in the plug-in's configuration?
pse
Post by pse »
The mistake that I made was not adding a trigger, and only realised after seeing similiar posts. It is working fine now.
kkl, thanks.
