I want to use a universal remote to get rid of too many remote controls. I am able to learn mostly all remotes, except some buttons on my DVR. The problem is my DVR also an universal remote(original from manufacturer) and it sends out three events/signals in a single press, regardless of modes. I guess the only way is to split/cut the unwanted event/signal from the DVR remote. Can this be done using EG. If yes, I will filter only the required signal to be learned in the universal remote. Can someone help please.
Split multiple events/signals
Re: Split multiple events/signals
Just capture one of the events, making sure it is unique for key, and ignore the other two.
When I use the learn IR code, it will capture the entire ir code. So even if i just drag a single event and execute, it is simply blasting all the codes as events. Please look at the attached image file. Thanks.
