I just recently started having a problem with the process is not closing when I specifically choose the 'exit' menu item inside of EG. I must kill the process in Task Manager.
Anyone else see this problem?
eventghost.exe process not closing - anyone else?
Re: eventghost.exe process not closing - anyone else?
I've noticed that if I don't give it a while to shut down before relaunching EventGhost, then it will hang and I have to go through task manager to kill the multiple EventGhost entries.
How long are you giving it before you go into task manager?
I'm having this same issue
Most likely, it is a result from one of your plugins or scripts that causes this delay ( a thread is still running/waiting/hanging, a connection is still open...)
If you start EG with a new fresh config, Im sure it will close correctly as you expect
