Anyone else have one? I will be using this with SageTV plugged into an extra S-Video port and mapped to channel 1, I have already done this with a regular DVD player and IR relay directly. This time I'll try and get some SageTV menus going that control the DVD player from the command line.
Sony DVP-CX985V 400 DVD Megachanger
I just ordered a USB-UIRT to go with my new 400 disk megachanger. So hopefully I will have control for that figured out. This way you need not rip the DVDs for use with TV Tuner applications, however you may only watch 1 disk per DVD player. Luckily the Sony changer I bought has selectable IR codes and so you can have up to 9 with a single USB-UIRT. Mine is the entry level megachanger and as such no RS232.
Re: Sony DVP-CX985V 400 DVD Megachanger
As expected EG made this a cakewalk too.
I got home last night ~11pm and right now it's 8am and I'm done. I was asleep at 12:30.
Basic controls via the USBUIRT.
You would need the changer to be set for IR codes #3 on the back of the unit.
This uses the network reciever plugin but you can change the events to whatever you like.
<EventGhost Version="941">
<Folder Name="SonyDVD400" Expanded="True">
<Macro Name="ChangerOn">
<Event Name="TCP.Changer-PowerOn">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0030 0018 0030 01ca', 4, 0)
<Macro Name="ChangerOff">
<Event Name="TCP.Changer-PowerOff">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0018 0030 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0030 0018 0030 01ca', 4, 0)
<Macro Name="FolderView">
<Event Name="TCP.Changer-FolderView">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0240', 4, 0)
<Macro Name="Open">
<Event Name="TCP.Changer-Open">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C8', 4, 0)
<Macro Name="Up">
<Event Name="TCP.Changer-Up">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0018 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 0198', 4, 0)
<Macro Name="Down">
<Event Name="TCP.Changer-Down">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 0199', 4, 0)
<Macro Name="Left">
<Event Name="TCP.Changer-Left">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 0180', 4, 0)
<Macro Name="Enter">
<Event Name="TCP.Changer-Enter">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C8', 4, 0)
<Macro Name="Right">
<Event Name="TCP.Changer-Right">
</Event>
USB_UIRT.TransmitIR(u'0000 0066 0000 0015 0060 0019 0018 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 019A', 4, 0)
<Macro Name="Top Menu">
<Event Name="TCP.Changer-DVDMenu">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C8', 4, 0)
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01B2', 4, 0)
<Macro Name="Play">
<Event Name="TCP.Changer-Play">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0030 0019 0018 0019 0018 0019 0030 0019 0030 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C8', 4, 0)
<Macro Name="Stop">
<Event Name="TCP.Changer-Stop">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0018 0019 0018 0019 0030 0019 0030 0019 0030 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C8', 4, 0)
<Macro Name="1">
<Event Name="TCP.Changer-Num1">
</Event>
USB_UIRT.TransmitIR(u'0000 0066 0000 0015 0060 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 0212', 4, 0)
<Macro Name="2">
<Event Name="TCP.Changer-Num2">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01FA', 4, 0)
<Macro Name="3">
<Event Name="TCP.Changer-Num3">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01FA', 4, 0)
<Macro Name="4">
<Event Name="TCP.Changer-Num4">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01E1', 4, 0)
<Macro Name="5">
<Event Name="TCP.Changer-Num5">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01F9', 4, 0)
<Macro Name="6">
<Event Name="TCP.Changer-Num6">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01E1', 4, 0)
<Macro Name="7">
<Event Name="TCP.Changer-Num7">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0030 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01E1', 4, 0)
<Macro Name="8">
<Event Name="TCP.Changer-Num8">
</Event>
USB_UIRT.TransmitIR(u'0000 0066 0000 0015 0060 0019 0030 0019 0030 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C9', 4, 0)
<Macro Name="9">
<Event Name="TCP.Changer-Num9">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01F9', 4, 0)
<Macro Name="0">
<Event Name="TCP.Changer-Num0">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0018 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01E2', 4, 0)
<Macro Name="Previous">
<Event Name="TCP.Changer-Previous">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0018 0019 0018 0019 0018 0019 0030 0019 0030 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01E1', 4, 0)
<Macro Name="Next">
<Event Name="TCP.Changer-Next">
</Event>
USB_UIRT.TransmitIR(u'0000 0066 0000 0015 0060 0019 0030 0019 0018 0019 0018 0019 0018 0019 0030 0019 0030 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C9', 4, 0)
<Macro Name="FastForward">
<Event Name="TCP.Changer-FF">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0030 0019 0030 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01C8', 4, 0)
<Macro Name="Rewind">
<Event Name="TCP.Changer-RW">
</Event>
USB_UIRT.TransmitIR(u'0000 0067 0000 0015 0060 0019 0018 0019 0030 0019 0018 0019 0018 0019 0018 0019 0030 0019 0018 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0018 0019 0030 0019 0018 0019 0030 0019 0030 0019 0030 0019 0030 0019 0030 01E1', 4, 0)
SageTV Dynamic Menus XML submenu snippet.
Find&Replace:
EG_IP_ADDRESS:1024 PASSWORD
<subMenuItem title="MegaChanger Controls" icon="STVs\dynamic_menu_icons\Menu-Changer-Controls.png">
<menu title="MegaChanger Controls">
<subMenuItem title="DVD Disk Controls">
<menu title="DVD Disk Controls">
<actionMenuItem title="DVD Disk Menu">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-DVDMenu" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Up">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Up" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Down">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Down" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Left">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Left" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Right">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Right" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Enter">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Enter" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Play">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Play" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Stop">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Stop" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Next">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Next" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Previous">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Previous" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Fast Forward">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-FF" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Rewind">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-RW" waitforexit="0"/>
</actionList>
</actionMenuItem>
</menu>
</subMenuItem>
<actionMenuItem title="Changer Power On">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-PowerOn" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="Folder View">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-FolderView" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionList>
</actionList>
</actionMenuItem>
<actionMenuItem title="1">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num1" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="2">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num2" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="3">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num3" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="4">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num4" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="5">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num5" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="6">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num6" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="7">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num7" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="8">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num8" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="9">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num9" waitforexit="0"/>
</actionList>
</actionMenuItem>
<actionMenuItem title="0">
<actionList>
<extCommand window="normal" command="C:\Program Files\EventGhost\EventGhost.exe" arguments="-n EG_IP_ADDRESS:1024 PASSWORD Changer-Num0" waitforexit="0"/>
</actionList>
</actionMenuItem>
</menu>
</subMenuItem>
