I ran eventghost for over a year without any problems but one day it went back to the default "example" file and I had to redo the configuration. Now when I do a command about 2/3 of the time it will execute it and then the eventghost icon turns yellow in the taskbar and will no longer work. Then I have to go to task manager to exit the program. Any help? I'm using version 4.01r1700 and Windows 8.1. Here's one of the main commands I use:
Macro: Start XBMC.
Event: Keyboard CTRL+Alt+C
Action: Start Program XBMC.exe (With "wait until application is terminated before processing" checked)
Action: Wait 0.4 seconds. (I was told it helps to put add a little wait time in a macro)
Action: Find Window XBMC
Action: Bring to Front
Eventghost turns yellow in Systems Tray and freezes.
Re: Eventghost turns yellow in Systems Tray and freezes.
If you saved the old config with another name then the "Example" you might still have it somewhere.Warpig17 wrote:I ran eventghost for over a year without any problems but one day it went back to the default "example" file and I had to redo the configuration.
The "Wait until..." option makes EventGhost wait until XBMC is closed so EventGhost will be "frozen" until you close XBMC.Action: Start Program XBMC.exe (With "wait until application is terminated before processing" checked)
That seems to have done the trick, thanks a bunch!jonib wrote:If you saved the old config with another name then the "Example" you might still have it somewhere.Warpig17 wrote:I ran eventghost for over a year without any problems but one day it went back to the default "example" file and I had to redo the configuration.The "Wait until..." option makes EventGhost wait until XBMC is closed so EventGhost will be "frozen" until you close XBMC.Action: Start Program XBMC.exe (With "wait until application is terminated before processing" checked)
