I read somewhere here about the OSD plugin been deprecated. Since I upgraded to the new one, I've tried the non-Plugin OSD action as well as the old plugin files (re-copied to folder from old version install) and they both result in error messages. Tried deleting and re-creating actions too.
Anybody wored around that?
OSD
- Bitmonster
Sent the error log, but further test indicate somehow it was a problem with the Macro entry (despite my having deleted it and remade it in the previos XML file)
- Did a File/New
- Insert Macro
- OSD
(and it worked!)
copied and pasted from the new file to the old xml file from <macro> to </macro> and then that worked too.
Perhaps it might be a bug and then again it might not.
- Did a File/New
- Insert Macro
- OSD
(and it worked!)
